Home > Td5 > SHOCKing ideas FOX or Terrafirma?
PoormansXS
United Kingdom 2002 Defender 90 Td5 CSW Buckingham Blue
Bored with 2 weeks off work so planning to visit alive and get some goodies. I’m going for their comfort springs, but I’m unsure wether to go for the fox shocks or the terrafirma 4 stage shocks.
Anyone got experience with either? I’m basically after as ‘comfortable’ a ride as I can get 🤣 terrafirma is tempted with the adjustability and being half the price! But if the fox is worth it maybe I’ll get them.
Any advice appreciated
Post #1025387 20th Feb 2024 11:17pm
LJMARSDEN
United Kingdom 2006 Defender 90 Other HT Java Black
I have fox 2.0 & Alive Tunings comfort springs on my own Defender 90. Its a much better ride and an easy solution instead of cobbling different setups together, Just a bit pricey.
I use the car for mainly road use and found it to be more than good enough but theres not much getting around the fact of its shorter wheelbase... Rolling with laughter
I'd recommend them. Thumbs Up
(2k Miles so far, ish) 4.0 V8 Defender 90
My Instagram
Post #1025407 21st Feb 2024 8:47am
TexasRover
I would just fit standard OEM Boge or Bilstein with the LR partner so they are designed for the car.
They are cheap and work well with the mass and standard springs. They are cheap enough to change them out more frequently. Dampers (shock is technically not the correct word) loose damping with use.
Post #1025411 21st Feb 2024 8:57am
bankz5152
Terrafirma youre throwing money away.
Fox, Koni, OME, Bilstein
Post #1025412 21st Feb 2024 8:58am
johnlad
I’d fit Britpart before using Terrafirma.
Had experience of there shocks snapping pins, rusting, seizing so no rebound.
Post #1025414 21st Feb 2024 9:01am
kenzle8a
Couldn't pay me to fit Terrafirma to a Defender.
I had B6's before on my 110 and they were pretty decent. I like the look of the Alive Custom Bilsteins or the Bilstein Advance Dampers (the black ones) a few places stock now.
Post #1025415 21st Feb 2024 9:03am
PoormansXS
Thanks all,
I guess it’s true what they say if it looks too good to be true then it probably is. I think I’ll go with the fox. Father in law has Bilstein on his and it handles great, I just think the ride could be a lot smoother.
Post #1025417 21st Feb 2024 9:09am
Screbble
Funnily enough, and mindful that I do little mileage and mainly on road, I’ve had Terrafirma shocks fitted to the rear for years without any issues. They’ve even held up aesthetically. My steering damper is also Terrafirma. Fronts are OEM. I am very aware of the significant number of issues reported regarding that brand which I do take a serious note of.
Now…what will I do when the time comes to replace?
I’ll either go Fox or standard/OEM.
Post #1025420 21st Feb 2024 9:32am
BaronDefenders
United Kingdom 2004 Defender 90 Td5 CSW Santorini Black
I haven’t heard much that is positive about Terrafirma shocks. On the other hand, I’ve only see positive reviews about Fox and Koni.
Personally, I use OME. I have them on three vehicles and find them quite suitable for my needs. Charlie
1949 Series 1 80 (SOLD)
2002 Td5 90 (SOLD)
2008 Freelander 2 (SOLD)
1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored)
1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE)
2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK)
2012 Puma 110 Zermatt Silver (Overlanding Build)
Instagram: @BaronDefenders
Post #1025426 21st Feb 2024 10:15am
balmybaldwin
Have you done any offroad with them presumably they are same as standard height? How do the springs behave? (I'm not into axle twisters, but don't want to find it too limiting as I do like to do the odd pay and play sometimes)
Post #1025665 23rd Feb 2024 12:36am
Welshsurferdude
Wales
Another vote for fox
used em on 2 previous defenders
and on my MTB's for years 2011 Santorini Black USW XS.
2015 Discovery 4.5 Black pack Firenze red XS
Post #1025666 23rd Feb 2024 12:59am
LJMARSDEN
I've done some light lanes and its supple, I'm in the same boat as you for not doing much of the tougher stuff just yet. Although, I imagine it would take some serious articulation to suffer from any chance of springs falling out of seats at the rear. I was really happy with them and glad I did spend the money on the whole kit.
The springs are Alives Comfort road spec, that'll be a bit lower roughly 1"-1.5" from what I remember. Note that these springs "level" the defender so the front arch will be sitting higher than the rear, they are not standard height. Again, I don't do anything extreme enough to require a lift...
This link is to a post of a couple of photos with the car "done" Whistle
https://www.defender2.net/forum/topic89722.html
This link is to a short clip of a lane in Leicestershire I stumbled across, not the harshest but hope it helps you.
https://www.youtube.com/shorts/bzX--Q89MLE 4.0 V8 Defender 90
My Instagram
Post #1025679 23rd Feb 2024 9:28am
Biscuits
United Kingdom 2001 Defender 90 Td5 CSW Epsom Green
I'm going Fox 2.0 with remote resevoirs on my TD5, being installed in a couple of weeks. (going to Juice Motors again)
Wanted Eibach comfort springs, but they don't do any with a 2" lift. So likely going to have to use OME, or keep the Britpart ones currently on it. 2001 90 TD5 Soft Top - Epsom Green
2024 90 D300 HSE X-Dyn HT - Santorini Black
Post #1025685 23rd Feb 2024 10:25am
Chicken Drumstick
Do you need the lift?
Flatdog offer standard rate springs in +2" length, so long springs, but give more like a 1" lift due to retaining the standard spring rate.
Remote res would normally only be needed for high speed off road or high speed rough terrain.
Post #1025690 23rd Feb 2024 11:33am
Biscuits
I'm running 35" BFG's, so the lift is needed. Seems OME and FD are the two main offerings.
Doing SCRAM AFRICA end of April, which is a LOT of high speed off road, so need as much damper volume as possible. 2001 90 TD5 Soft Top - Epsom Green
Post #1025691 23rd Feb 2024 11:36am
