Home > Expedition & Overland > Poptops - the definitive list
Page 3 of 5 <12345>
United Kingdom 2003 Defender 110 Td5 HT Alaska White
Im not following the instructions exactly as i am building it off the car and i bought a spare roof when i changed my rear tub over.
so far it started with i gave everything a clean down and used UPOL Acid 8 Etch primer 2 coats before i got started just because everything covered and its a nice base to work from. I then laid my spare roof upside down on some stands and laid the upper frame ontop of it measured it equally and lined it all up scribed the holes then drilled and riv nuts set. I also used Duralac jointing compound between the Stainless rivnuts and the aluminium frame.
PXL_20240103_155236169 by Tom Bayford, on Flickr
After that i then lined up the lower hinge on the front and marked it out and drilled it through but i used Cleco pins to hold it in place while i drilled i didn't want to put a temporary rivet in as drilling it out there would be no way to clean it out so it could forever rattle around and annoy me! When you set the hinges be careful as our top frame is 100% square and is 5mm off on the right hand side (looking from back) so when you set the top hinge you can fine tune the alignment.
PXL_20240118_140755680 by Tom Bayford, on Flickr
Thats pretty much where i am up to for the moment as work keeps getting in the way and im trying to get it to a point i can take the roof off and put the pop top on during my shift days off. 110 Td5 Ex Utilities slowly converting into a pop top camper one day
Build thread:https://www.defender2.net/forum/post1024784.html#1024784
Post #1024586 13th Feb 2024 11:30am
pistonfields
Switzerland
looks good! not a fan of the stainless rivnuts. Have you had previous experience with the Duralac stuff? My fear is it gets pressed out and becomes useless.
Post #1024588 13th Feb 2024 11:36am
34064
I have used it extensively on the trains i work on with good results hence the choice i just made sure to get a good coating of it on there first.
You'll also need a strong rivnut tool for them as they are challenging i ended up buying a long handled one which also has the advantage of being able to do Defender seat riv nuts too 110 Td5 Ex Utilities slowly converting into a pop top camper one day
Post #1024590 13th Feb 2024 11:52am
pistonfields
Switzerland
I have an okay tool with long handles. Still chinesium but I can't afford a professional one. I'll try to drill all the holes and do a dry fit of at least the base frame before painting it. That should help with corrosion resistance on the rivnuts and similar.
Post #1024591 13th Feb 2024 11:58am
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
pistonfields wrote:
picked it up yesterday Thumbs Up
That's not how they are supposed to be installed.
Rolling with laughter
SCNR; all the best for the installation.
Post #1024600 13th Feb 2024 1:45pm
pistonfields
Switzerland
Quick update: as of now 5 months have passed since ordering and I'm still waiting for the canvas and one missing bag of screws to be shipped. Bit underwhelmed with customer service...
Post #1034601 13th May 2024 9:47am
34064
Pistonfields your not alone I have my all assembled now and on but we ordered in November 2022 and still waiting on the German VAT to be paid back. His service is shocking too almost as bad as his instructions! 110 Td5 Ex Utilities slowly converting into a pop top camper one day
Post #1034607 13th May 2024 11:21am
pistonfields
Switzerland
yeah he's a nice chap for sure but business wise a complete <insert>. Honestly, even if quality and everything will be brilliant I'm not sure I'd have a good feeling recommending it to someone else. Not unless they are fully aware of how things might play out.
Post #1034675 14th May 2024 7:42am
steveww
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Bronze Green
Post #1034714 14th May 2024 11:37am
8619simon
Wales 1995 Defender 110 300 Tdi CSW Epsom Green
Drivelodge
Found this thread really useful and helped me drive down my choice to the Drivelodge PopTop. Just had this fitted by Mick at Pennine Overland (L.R.Bits).
So far really pleased.... No perceivable impact on handling or mpg and nice low profile which was one of my key criteria. I opted for his Explorer awning as well and the roof rack so I can bolt on my shower cube and also 270 degree awning.... More awnings than you can shake a stick at Rolling with laughter Rolling with laughter
He's also just developed some quick release roof bars that go over the top and allow you to carrry loads but only take a minute to take off when you need to pop the roof.
A few pics for information and I'll report back when used more in anger.
Post #1038991 2nd Jul 2024 9:57pm
LR Nuts
I used similar construction principles on my L663, to give a small 'one-man' awning.
Telescopic poles mounted on Molle plates (Left&Right) to form a framework and a canvas over the top.
The rope n eyelets give it an olde LR canvas look. Very Happy
Post #1039058 3rd Jul 2024 6:06pm
BrickBox
Curious why you have a 56mph speed limit restriction sticker? 2017 5.0 V8 Supercharged RRS SVR
2008 2.4 110 Utility Station Wagon XS.
Post #1039063 3rd Jul 2024 6:58pm
LR Nuts
It's NOT a restricted sticker, but a 'sign' that I cruise along at 56mph (mainly on motorways). As a retired person I'm not in any hurry.
Post #1039064 3rd Jul 2024 7:03pm
pistonfields
Switzerland
finally managed to find the time to do the installation. More work than expected and definitely lots of little adjustments neccessary. If someone is looking for a bolt on-solution this definitely isn't it. Still not finished yet, had to wait for the paint to dry... Current state:
related: what did you all chose as a bed solution? slatted frame or just a wooden board? Spring elements like the Froli system? Question
Post #1044979 6th Sep 2024 7:13am
34064
I have used two sections of 18mm ply with air holes cut in one section is fixed as such over the cab then the smaller bit in the middle can be removed to increase space if needed 110 Td5 Ex Utilities slowly converting into a pop top camper one day
Post #1045002 6th Sep 2024 10:50am
Page 3 of 5 <12345>
