Home > Tdi > Replacement fuel solenoid wire
PAT303
Australia 1998 Defender 110 300 Tdi SW Alpine White
Does anyone know if an OEM fuel solenoid wire is available, I've made a replacement using a spade terminal but it falls off over corrigations, if not a wire the original locking clip, thanks
Post #1024175 10th Feb 2024 11:00am
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
Not sure what you mean by 'locking clip'?
It's just a female shielded spade connector. If it's falling off then tighten up the connector with pliers or get a better connector.
Post #1024181 10th Feb 2024 11:48am
Martin
Site Admin
Yes, I have them, and I can supply as a kit of parts or with wire attached.
But I imagine the cost to post to Aus massively outweighs the cost of the actual connector Shocked  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1024184 10th Feb 2024 12:42pm
PaulMc
The fuel cut-off terminal (C0198), is a TE/AMP 6.3mm 'Posi-Lock' terminal with a Black cover (AAU1010)
They're used in multiple locations on a Defender. Paul.
Post #1024260 10th Feb 2024 10:41pm
donmacn
Thanks very much for posting that picture! Every day’s a school day.
I didn’t know such thing existed, and as ‘OldSkool’ has said above I’ve just used normal insulated spade terminals here. Survived for about 10 years or so since the last time I replaced one so clearly not a massive issue, but now that I know about the “proper” thing I’ll get some ordered.
Ta Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #1024319 11th Feb 2024 12:48pm
PAT303
Don't work out here mate, the constant vibration from corrigations loosens them to the point they fall off, I've squished them with pliers and within weeks they are loose.
Post #1024437 12th Feb 2024 12:30am
PAT303
Paul, thanks mate, exactly what I was after, cheers.
Post #1024438 12th Feb 2024 12:31am
