![]() | Home > Puma (Tdci) > Defender 2.4 TD4 don't start |
| xmotor Member Since: 17 Jan 2024 Location: la balme de sillingy Posts: 20
Hi,
I am thinking about the shunt of pins 3 and 4 behind the speedometer. I removed the two pins from the connection and soldered them together. But at the connection level is what I need to connect together the slots of pins 3 and 4 so that the two pins in the dashboard are connected. Olivier |
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6725
No, you have done the right thing, join the wires.
Now the wire from the alarm 10AS goes direct to the engine ECU, bypassing the cluster. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
Ok, that's already a good thing.
What is your prognosis for my non-starting failure? |
Hi Martin, I have never start the defender 2.4 TD4. By joining the wires directly without going through the dashboard, does this result in a DTC 1602-31? Have you got a good procedure for priming fuel on a defender 2.4 TD4. I think the injectors don't open. I have high pressure fuel pressure but the defender won't start (not even smoke coming out of the exhaust Thanks for your help. Olivier |
| MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2509
There is a diesel priming tool for the 2.4 Tdci. The poor man option is to blow/pressurize the fuel tank until no bubbles come from the fuel line valve. Puma 110" SW
Yes I have the tool and I see the fuel coming up to the inlet of the pump. Then I disassemble the tool and try to boot but nothing.
I tried to open the injectors one by one to get the air out of the pipes but without success |
| Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2535
Is the Nanocom still not seeing the engine ECU ? If so it could be an ECU issue, I.e connector, fuse, wiring ,a faulty ECU or a CAN bus issue. |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18031
If the engine started and ran the first time it is unlikely that there is any particular fuel system problem, such as air in the system. It is more likely that something else has gone wrong whilst you primed the oil pump. I assume the fuse you refer to is BJB Fuse 5 (in which case I am a little surprised that the engine cranked)? I presume that you cranked the engine on the starter in order to prime the oil pump? My initial suspicion is that for some reason the ECM hasn't powered back up correctly. If the ECM has no power or is missing some of its power inputs then the Nanocom won't see it and the engine won't run. Does it actually still crank? Another possibility, although I think it is unlikely, is that whilst cranking the engine to prime to oil pump with the ECM powered down, you have over-pressured the fuel rail and popped the relief valve. If this is the case you will have little or no fuel rail pressure and the engine probably won't start, but this on its own would not explain the unresponsive ECM. Also for this to happen the VCV would have to have been fully open when cranking to prime the oil pump, and I am not sure if 5this is possible - again it depends on what you actually disabled by removing the fuse. I suggest your first priority is to investigate why the ECM is unresponsive and check that there is power everywhere there should be. I don't think you have a fuel problem at this time, I think you have an ECM problem. Check BJB Fuse 5, the un-numbered fuse in Holder P110 (C0602), CJB Fuses 38 and 39 to begin with. Assuming that the engine is cranking, then failure of either the crankshaft or camshaft position sensors will cause it to fail to fuel. It will aslo fail to fuel if it believes that there is no fuel in the tank, however none of these would cause a loss of comms between Nanocom and the ECM. |
Hello I did a reset of the vehicle with the nanocom and the engine ECU reappeared. But I still don't have the engine starting. I now think my problem is with the fuel system |
[/b] Thanks a lot for your help. |
i've got again the DTC 1602-31. Is it because i've link pins 3 and 4 behind the instrument pack?[/u]
I know Martin has stated in another topic that when bypassing the 2.4 instrument cluster by bridging pins 3 and 4 you do get a DTC but it does not affect the starting or running of the vehicle.
See near bottom of page 7 of this topic https://www.defender2.net/forum/topic47486...p;start=90. I’ve copied below and highlighted text in bold.
One thing you can do with the Nanocom, and you need the latest software build to do it, is to resync the 10AS with the engine ECU. You may have lost the sync between the two units so worth seeing if that’s your problem. |
In which menu to go to synchronize the ECU and AS10. I have the latest version
I have not had the need to use it to date , however it’s called EMS resync and I believe it is the last option on the menu once you have selected defender, Puma, defender Puma 2.4.
see the Nanocom emulator for details https://emulator.nanocom-diagnostics.com/ |
