![]() | Home > Modifications & Maintenance (L663) > Most useful mods you’ve done so far? |
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1472 ![]() ![]() |
Blimey ![]() ![]() |
haymeister Member Since: 24 May 2021 Location: Saitama Posts: 291 ![]() ![]() |
What's wrong with stop/start?
The engine running at traffic lights/in traffic isn't great for air quality or the pocket, and unlike the early days the lag is almost gone. I thought brake hold was a gimmick, but I'm converted. 2 most useful mods/accessories: Lighting: Namely reverse lights, and LED boot light https://www.powerfuluk.com/products/led-re...&_ss=r https://www.powerfuluk.com/products/boot-l...&_ss=r Boot mesh luggage rack (takes advantage of the boot height and makes it a lot more usable) https://www.powerfuluk.com/products/mesh-l...-110-model 22MY Defender 110 D300 S in Pangea Green and Contrast White Roof IG defender_japan "Hulk san" |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5117 ![]() ![]() ![]() |
I like brake hold, although not too keen about how it comes on in this defender. needs more of a defined press than other JLRs
Auto stop start, i just accept it - its a pain at times, its ok at times What is annoying is the car safety feature (thanks whoever sued JLR in america) that the car likes doors shut, seat belt on, a small sample of blood otherwise it puts the car in park. Which is a real pain when you need to open gates or move around something on a farm. etc Mike |
Get one of these dog seat belt things and use either of the square seat belt inserts.
It means that you can get in and out and do what you need to do without having to put the seat belt on and off. ![]() https://www.petsathome.com/shop/en/pets/pe...lsrc=aw.ds ![]() Click image to enlarge Eiger Grey MY23 D250 SE with bits. Known as Noddy. |
Cheshire110 Member Since: 26 Jul 2013 Location: London Posts: 2789 ![]() ![]() |
For me the ‘must have’ modifications have been:
- BFG AT tyres - fit and forget and I’ve never worried about punctures or getting stuck off road since. With all the tech assistance too it just makes off roading too easy. - GAP tool to turn off stop/start and seatbelt reminder - makes using the car in the real world (especially when off road, or launching boats, towing & hitching trailers etc) just so much easier - devon 4x4 rock sliders - again just so much more peace of mind when off road (or even just manoeuvring through London’s 6’6” width restrictions!) - genuine rubber mats throughout - not that glamorous but they are bloody well made and contain all the dirt and water you bring into the car with you Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
Lightwater Member Since: 28 Jun 2020 Location: Sydney NB Posts: 75 ![]() ![]() |
A few options for your air system. Moisture trap, after cooler with refrigeration option. ![]() ![]() ![]() Click image to enlarge Parallel 3 compressors together for increased speed. Visitor - Freelander owner |
muidumees Member Since: 29 Jan 2024 Location: Home Posts: 4 ![]() ![]() |
Most useful - shutting off the seatbelt alarm. Had it looked up already before delivery of the car.
Just takes 10-15 times to insert the belt buckle with ignition on. No GAP tool required for this middle console storage tray being the second most useful. most useless - rear roof spoiler. But damn, it looks good ![]() next is some additional lights. |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3782 ![]() ![]() ![]() |
Does the belt buckle alarm stay off after doing that, or do you need to do it every time you get in?
Never heard the alarm again. There was some youtube instruction about it - ignition on, keep the seatbelt button pressed and insert the buckle until you hear a "ding". Also worked on friend's range rover.
The seatbelt alarm stays off permanently, same on the Freelander. I can't quite remember but the 10 times within a minute might need redoing if you have disconnected the battery, but other than that it stays off. Visitor - Freelander owner
Brilliant, nice one. Can you turn off the bong when the door is open?!
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3443 ![]() ![]() |
Apparently not, even with the GAP tool.
Mr Fox Member Since: 10 Sep 2011 Location: green & pleasant land Posts: 1047 ![]() ![]() ![]() |
Has anyone been the guinea pig and found out what soft, zip up, nylon bags fit in the rear door pocket? I'm thinking Maxpedition, 5.11, etc.
I've tried the Maxpedition Fatty Pocket ( ![]() |
zilch Member Since: 11 Sep 2019 Location: Whitsundays & Sydney Posts: 849 ![]() ![]() |
Best mod we have done on our P400 is the rear brake caliper swap (D5 OEM apparently) and
fitting decent 18” wheels and Falken Wildpeak tyres.. bye LR OEM 19” wheels and Goodyears AT adventures (Swiss cheese sidewalls variant) yet another pommie bar steward down under MY20 110 P400 SE Defender MY10 3.0 RR Sport |
