Home > In Car Electronics > TD5 Dipped Beam Stopped Working - Whilst converting to LED
ijefferyes
United Kingdom 2002 Defender 90 2.5 TD CSW Zambezi Silver
I am trying to convert my 2002 TD5 from standard headlights to LED Lynx Halo headlights.
Took the front apart last weekend and then this weekend tried to install the new lights.
After only plugging in one of the LED headlights, I switched on the lights to check they were working. At this point, I didn't get any dipped beam light. So, I plugged the standard light back in but still didn't get any dipped beam and strangely neither front light works.
Full beam comes on from both sides, but no dipped beam on either.
Tried swapping both headlights to the LED lights. Still no dipped beams, but full beam works.
So, what have I done?
Checked fuses and all look good. Rest of the lights, side lights, indicators, fog light seem to be fine. Unfortunately, didn't think to check that the headlights worked today before making changes, but they worked last weekend.
I can't see a dip/dim fuse under the wing, although there does seem to be a plug, which goes live when the slide lights come on.
Post #1022748 27th Jan 2024 9:36pm
If you’ve tried both sets of headlights, then there is an issue with the dipped circuit not the lights.
The ground is fine as you have main beam.
Be sure to check the fuse for dipped, if that is in-tact then have a look at the light switch and main beam stalk.
Check the power on those, check for any burnt out contacts or damaged contacts.
Identity which circuits are which can bridge if need be to see if it is the switch or stalk at fault.
If either is replace.
If those circuits seem okay, see if there is any aftermarket lighting loom fitted for the headlights.
If there is, there could be a supply fuse gone there or trigger missing from the existing loom.
You may have accidentally popped a fuse somewhere, and if that is additional to the LR fuse box that may be the culprit.
I seem to remember, though don’t quote me exactly but I seem to remember although the stalk is for main beam switching, the dipped from the dipped and sidelight switch goes though those contacts.
Those contacts can get worn, damaged, or burn out.
A Multimeter will help, some little clip on test leads may be useful too just only use them momentarily due to current if you use the standard headlight.
Personally I’d check it all with the engine running, that’s the scenario you would be using all the lighting. Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1022754 27th Jan 2024 11:24pm
ijefferyes
Thanks for the feedback.
Looking in the fuse box if I am reading the symbols correct, it suggests there is a fuse per side, both dipped and full i.e. four fuses. Will get a picture tomorrow.
Again it would be weird if I had tripped the fuses for both sides, without having touched one of the sides.
The wiring loom is also unmolested.
I think as you suggest, time to check the switch and get the multi-meter out. The switch has gone before, but long time ago. Then it was more intermittent than this.
Ian
Post #1022757 28th Jan 2024 12:28am
ijefferyes
All sorted. Didn't realise the TD5 could also have the relay behind the dash. Have bypassed this and it now works!
Post #1022813 28th Jan 2024 3:56pm
Glad to hear you managed to get it sorted out. Thumbs Up
Even though you have gone LED, which will extend the light switches life span greatly.
Don’t discount the idea of fitting an additional lighting loom, as that can reduce the current through the switch even further down to under 500mA. Or 0.5A and lower.
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1022857 28th Jan 2024 9:10pm
