Home > Puma (Tdci) > Boosts on Puma don't seem to fit
steveyorks
England 1993 Defender 90 200 Tdi CSW Barolo Black
My 2009 Defender station wagon is currently running steel wheels with 7.50 Michelin tyres which I want to upgrade to something quieter and better mannered on the road. I bought a set of Boost alloys that I have painted athracite to match the checker plate thats on the car. All good so far until I came to fit them today. I tried putting the wheel on the front but couldnt get the nuts on properly as the wheel wasnt sitting flat. It was as though the centre was too proud to allow the wheel to sit properly. Memories here of 20 years back trying to put alloys on 90s with drum brakes! Now I am fairly sure these wheels came off another Puma so what am I doing wrong? Is the fit so tight I need to look at the nuts on the driveshaft?
Post #1022722 27th Jan 2024 6:34pm
Mdm
assume you have the correct alloy wheel nuts for the wheel?
ar the wheels genuine ones?
have they been refurbished (as powder coat adds thickness more than paint)
and sometimes the half shaft flange nuts just need a tweak to put the flats outards.
Post #1022724 27th Jan 2024 6:46pm
steveyorks
Genuine wheels that I rubbed down and painted and with the proper LR nuts that came with them. You may be right with the drive shaft nuts. I just wondered if the fit was that tight or if anyone had experienced the same? Very annoying I was all geared up and giddy!
Post #1022726 27th Jan 2024 6:54pm
Mdm
ping a picture of the wheels and hub when you get a minute up here and we can have look
Post #1022728 27th Jan 2024 6:56pm
Dinnu
Do you have standard drive members? Some aftermarket DMs will cause similar problem. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1022760 28th Jan 2024 1:22am
steveyorks
I would imagine I do. The vehicle was owned by the Council before me and everything fitted is genuine Land Rover, even the checker plate kit. I suppose my alternative is to sell the Boosts and put some different tyres on the steel wheels but I dont know if I can get 235's on the rims.
Post #1022789 28th Jan 2024 11:31am
Dinnu
A picture of the wheel hub, even with the steelies on, will help to see the problem. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1022792 28th Jan 2024 11:53am
Boosts definitely fit on standard hubs so either there's something non-standard or something's happening to confuse you. Either way, photos of the hub and ideally the inside face of the Boost should enable diagnosis.
Post #1022799 28th Jan 2024 12:49pm
steveyorks
Post #1022804 28th Jan 2024 1:54pm
Is there some kind of extra thick gasket between the DM and hub there?
There should only be a lightly greased paper gasket between the two.
Are you completely sure they are genuine boosts and not copy’s? I know that copies do exist, which is why unusually low prices exist on some listings.
But if they are genuine, then they must be, so long as they aren’t passed off as genuine.
Perhaps you can take internal measurements, and compare with someone who has them, and the hub.
I’m sure someone on here probably has a wheel off right now or can do to compare.
What size spanner fits the DM bolts? Perhaps sone aftermarket ones were fitted that weren’t quite correct in the past. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1022806 28th Jan 2024 2:12pm
If you clean the hub well, paying particular attention to the outside face of the bit the drive flange is bolted to, the angle between this and the hub mating face, and to the lobes of the drive flange I reckon your wheels will fit. There are intended to be located by having a close fit between the listed areas and the inside of the wheel, so also check the inside face of the wheel for damage.
I reckon your problem is simply a paint, rust, and grime issue, and a bit of cleaning (and a smear of copper grease on the locating and mating faces) and you will be sorted.
There is nothing non-standard there, expect possibly for the amount of paint and absence of rust.
By the way, you are missing the rubber or plastic dust cap that should be fitted over the end of the halfshaft and circlip.
Post #1022808 28th Jan 2024 2:28pm
Mine was missing those end caps before I fitted the Ashcroft DM’s, I do not ever remember having caps present. At least I had not lost them.
Makes me wonder if they were actually fitted at all, seeing as they are hidden behind alloys.
Not having some protection there, means more wear and also getting dry as well and increased fretting.
Eventually leading to some human fretting in the event of failure Laughing _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1022809 28th Jan 2024 2:42pm
Martin
Site Admin
Boosts with original factory finish have no paint on the mating surfaces and inside the part which sits on the hub/drive member.
Refurbed wheels typically get paint/power coat over everything. You probably need to clean up the inside of the wheel around where it fits over the drive flange to get the correct clearance back.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1022815 28th Jan 2024 4:23pm
steveyorks
All excellent news then and a job for next weekend, thank you everyone for your input. It did have the rubber caps fitted but I took them off to see what was going on and if they could have been the issue. I will update once I have had a go next weekend and thanks again.
Post #1022832 28th Jan 2024 6:35pm
steveyorks
All done, took a l
ot of pressure and cleaning but what do you think? Drives so much better and quieter
Post #1023459 3rd Feb 2024 4:49pm
