Home > Technical > Ignition Jammed |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4522 |
AA job then a dealer. Happened to my Puma and the only solution is a new barrel. It is time consuming and therefore expensive. Despite being given key number and chassis numbers etc when mine was collected I had two new keys which do not fit the door lock. Not a big deal as I use the fob but given the info given to them they should have got a barrell that was the same as the old one, so beware.
If you have a second key try that but take care that it does stick in the barrel as you will be in bother then, It could be worn key but from your description it sounds like the barrel mechanism. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
24th Nov 2011 7:44pm |
daviec1 Member Since: 30 Nov 2010 Location: Ayrshire Posts: 246 |
Yep - stuck coming out, so could not stop the engine - now won't go back in at all - either key.
Oh well, AA in the morning then. 2001 TD5 110 DCPU in Bonatti Grey |
24th Nov 2011 7:47pm |
If it is still going stall it but shift it somewhere convenient first! 1982 88" 2.25 diesel
24th Nov 2011 7:49pm |
Hmm - been advised by local specialist of steps that I can take to get it going - as will need to get ignition barrel replaced completely, no probs.
And for obvious reasons I am not posting the solution on a forum..... Still a pain in the backside though - snow better hold off until I get the vehicle back - waiting on order of new locks & ignition barrel (so only 1 key!) 2001 TD5 110 DCPU in Bonatti Grey |
25th Nov 2011 12:15pm |
well, instructions from garage did not help - looks like it will be the AA to get it started then hope it doesn't stall on the way to the garage on Wednesday
and if AA cannot get it started - delivered straight to garage by them. 2001 TD5 110 DCPU in Bonatti Grey |
28th Nov 2011 8:54pm |
