Home > Puma (Tdci) > Work Lamp
defender75
2009 Defender 110 Puma 2.4 XS CSW Chawton White
Work Lamp
I have a work lamp. I know there is a always hot plug behind one of the speakers. I also have YUG 000540LNF and the back connector. What is the easiest way to wire up a work lamp?
thanks
Post #102100 23rd Nov 2011 10:38pm
PaulMc
Re: Work Lamp
thanks
There's a fused permanent live behind the RH rear lamp cover, on a Purple wire in C1692 (there's also an earth, on a black wire, in C1692) -
Wiring for the switch YUG000540LNF is detailed here -
http://www.defender2.net/forum/topic552.ht...p;start=15
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Paul.
Post #102237 24th Nov 2011 6:44pm
defender75
Thanks, Anyone know if there is plug for that will fit C1692 so I don't have to cut the end off?
Post #102240 24th Nov 2011 6:52pm
szracer
England 2010 Defender 110 Puma 2.4 USW Stornoway Grey
http://www.polevolt.co.uk/acatalog/Mulitple_Connectors.html
(third one down)...
HTH,
2010 110 XS USW (the slow one)
1960 Alfa Romeo Giulietta SZ (the fast one)
2005 Ducati ST3
1954 Sunbeam S8
Post #102245 24th Nov 2011 7:07pm
defender75
awesome thanks
Post #102251 24th Nov 2011 7:31pm
MuddyMarky
United Kingdom 2011 Defender 110 Puma 2.4 DCPU Stornoway Grey
Go on then....what are the C0308 & C0309 for? Smile Mark
2011 110 XS DC
Stornoway Grey
Post #102287 24th Nov 2011 8:29pm
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
Curious too .... anyone know? Very Happy Guns and Landrovers .... anything else is irrelevant.
Post #102293 24th Nov 2011 8:39pm
PaulMc
Rear RH Speaker.
. Paul.
Post #102300 24th Nov 2011 8:49pm
Dave-H
So .. if there is a plug under the cover for a worklamp, is there an associated plug at the dash end for a switch? Guns and Landrovers .... anything else is irrelevant.
Post #102301 24th Nov 2011 8:54pm
richuk
Re: Work Lamp
Could you tell me what the fuse is rated at and where it can be found? I am thinking my preferred method would be to fit a 12v cigar lighter socket. Then have a work light with a trailing lead and plug etc. This has obvious advantages of allowing other equipment to be plugged in. Although most probably the kids game chargers Whistle
Thanks Rich
semper in excretia sumus solim profundum variat
Post #102349 24th Nov 2011 11:52pm
defender75
Was all set to wire my work light to a relay behind the speaker but now I also want to put a 12v recepticle in the speaker housing.
Do I need a second relay? Should I get a fuse box? Ideas?
Thanks
Post #102361 25th Nov 2011 3:09am
PaulMc
No there isn't, the plug at the rear is meant for an accessory socket.
Thanks
The Purple wire goes back to Fuse 2 (20A) under the driver's seat, it also supplies the towing socket pickup connector.
Thanks
The Purple wire is fused at 20A, the wire from the fuse box to the towing socket pickup connector is 3.0mm2, the spur to C1692 is 2.5mm2
. Paul.
Post #102386 25th Nov 2011 10:03am
When I fitted rear worklights to my DC, I already had a socket fitted to the aux connector in the back (which is also connected to the connector for the trailer socket, by the way).
The DC of course doesn't have a rear door, but despite this the harness to the back still has the wiring for the heated rear window and rear wash/wipe. For ease of wiring, I used the HRW connector for the worklight.
The vehicle had all the wiring for the HRW except the switch (even the relay was already there!), so fit the switch and connect the worklight to the connector at the rear and hey presto! instant solution. Apart from the fact that the symbol on the switch is a HRW symbol, everything you need is there - it is fused, relay controlled, the switch is illuminated when the lights are on, and there are warning lights on both the switch and the instrument panel. No additional wiring required!
The HRW switch is, of course, only powered with the ignition on, which is ideal if the workilghts are traditional bulb type. Mine are LED lights (very low current) so I have spliced the live to the HRW switch into the permanent live to the hazard switch. Worklights now work with or without the engine running.
I appreciate that this is no help if you have a vehicle with a rear door, though.
Post #102422 25th Nov 2011 12:46pm
defender75
Thanks[/quote]
.[/quote]
Not sure I understand the respone
Post #102459 25th Nov 2011 5:12pm
PaulMc
Sorry, I should have made that a bit clearer Embarassed
What I meant by my reply was that the wire gauge and fuse are large enough to support an accessory socket (10A max) and a worklight (typically - 55w, which is just under 5A) without using a relay or an additional fusebox.
. Paul.
Post #102469 25th Nov 2011 5:42pm
