![]() | Home > Puma (Tdci) > Instrument binnacle wiring diagram needed |
mata Member Since: 24 Jan 2014 Location: Manchester Posts: 153 ![]() ![]() ![]() |
I've shared the whole wiring diagram on my icloud for you, see below. Looks like you need page 21 where the connection from sidelights is shown on pin 25 of the connector onto the instrument cluster. Id start br probing this pin with the sidelights turned on.
https://www.icloud.com/iclouddrive/007TACg..._to_751062 |
steveyorks Member Since: 08 Apr 2013 Location: west yorkshire Posts: 193 ![]() ![]() ![]() |
Thats fantastic thank you very much. Its interesting that I also have the ns side lamp not working after I had some paint work done on that wing. Seems coincedence to me so it may not be the actual cluster thats at fault as from what you say there is a connection between side light and cluster. So I have pulled the fuse to ns side light and its gone. Replacing that has also fixed instrument illumination. I feel a bit of a fool to be honest but I can live with that now my problem is sorted so again thank you very much and the wiring diagram will come in handy!
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 823 ![]() ![]() |
could I also say thanks for the wiring dig which ive taken the liberty of downloading.. I have a 2014 2.2l tdci 110. and ive not come across a wiring dig yet that seems to suit the vehicle, so I thought id copy yours and see if that is any better than my Hanes manual ![]() also nice to see the op got a result an his issue |
Great stuff , happy to help!
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1125 ![]() ![]() ![]() |
Here you go: https://onedrive.live.com/?authkey=%21AMrv...9C85C7C171 by our member dgardel |
Thanks for taking the time👍
I'll have a browse through that lot as well.. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20978 ![]() ![]() |
Check the connector is secure to the rear also, it’s been known for them to get loose or not be fitted snug.
Worth checking at least before investigating further, though you probably already have. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
