![]() | Home > Puma (Tdci) > Help needed !!!!! |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 818 ![]() ![]() |
You need to get the fault codes read and take it from there👍
bunnyman Member Since: 29 May 2013 Location: herts Posts: 125 ![]() ![]() ![]() |
Ate there any serious faults or just likely be mass air flow clean?
Tdci 09 plate |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 1031 ![]() ![]() ![]() |
Not sure how close these are to you.
https://www.southwestlandrover.co.uk/index.php 2017 L494 Range Rover Sport SVR 2008 2.4 110 Utility Station Wagon XS. |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3600 ![]() ![]() ![]() |
Get an OBD reader with wifi capability and download an app on your phone. You will be able to read the error code, and even reset it to see if the error comes out again.
The OBD reader is worth every penny, and not a lot of pennies will go i to it 😂 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1857 ![]() ![]() ![]() |
If its running fine, normal temperature, no nasty noises, oil ok etc etc it may go out after 6 stop start cycles or may need clearing / checking codes.
Don't overly worry, keep an eye on temp and have a good weekend! |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5986 ![]() ![]() |
Check your air filter is dry and ok.
Hi all have cleaned the mass sensor , I have a code reader at home but didn’t want to go th a garage and pay out if possible
Just to be told it was the sensor . I was more worried that I might cause some major damage if I kept driving it even thou it driving fine |
Daphne Member Since: 22 Nov 2023 Location: Kent Posts: 27 ![]() ![]() ![]() |
It’ll go into limp mode before any damage is done.
Thank you all for your replys
