![]() | Home > Puma (Tdci) > Rattle under load (sorted, injector problem) |
Waka56 Member Since: 08 Nov 2023 Location: Hamburg Posts: 171 ![]() ![]() |
I removed the spring to put it back on again. It seems like the actuator might be toast, and at its idle position the boost might be a bit more open than normal. If anyone can check their actuator idle position that'd be nice. I think I'll just get a new one. Making my Defender great again. (Or trying to at least xD)
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2472 ![]() ![]() |
This topic may be useful if replacing the actuator. It’s for the 2.2 so part numbers will be different but I expect it’s a very similar process for the 2.4 https://www.defender2.net/forum/post853115.html#853115
Here are the details from member LandRoverAnorak ( 2.2 2013 puma 110 )
For the price, changing the actuator for a new one will probably be what I go for. Too many little problems to live some doubts around. Making my Defender great again. (Or trying to at least xD)
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20942 ![]() ![]() |
You may as well change it in this instance, it could well have been what was causing issues in the beginning hence the barn fix with the spring previously done.
I know what the noise is people talk of the induction noise issue, it sounds like a jet engine spooling up in a way then often goes after a couple of minutes, I had it once or twice just after starting up and driving away when cold. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Oh forgot to add…
Looking at those pics LRA kindly did the write up for, if that’s a 2.2 the EA to turbo linkage is different to the 2.4, that I do know. It’s a very similar set up but the an actual linkage is different but the mounting pivots more or less are the same I think. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Yup, I have the 2.4. Gonna order tonight
![]() The noise is nearly gone, not sure what fixed it, but I'd say the new oil, or the new diesel.. Maybe the MAF.. ![]() ![]() ![]() |
Maybe the spring being removed stopped the noise.
![]() ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Its back on, did not want to risk the turbo going crazy xD
The error is still on, don't worry, I'm not going anywhere. Next on the list will be the whippers, the light inside that does not turn itself fully off anymore, the blinkers that are going crazy, the direction that is not direct, the clutch/gearbox, and much more haha ![]() |
That spring is likely to do more harm than good, I suggest you remove it.
Just ordered the actuator, gonna test drive it without the spring until then, you guys win
Take it with you just in case, but I’m sure you can kiss goodbye to the auxiliary spring for good very soon.
You’ll probably find the performance to be much better! ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
So, I removed the spring a couple of week ago, and replaced the actuator today with no difference at all. After a short drive on the motorway the engine goes into limp mode, until then the car runs like a dream.
So p0234 still there, rattle still there.. Could a P0234 (turbo overboost) have anything to do with a faulty EGR? My airbox is also not sealed properly, the top part is a bit broken.. I also heard that EGR could create a rattle, two birds with one stone would not be too bad ![]() |
The EGR, can make noises when driving, of which I seem to remember is usually a problem as it should only do self cleans etc when turned off. If it’s making a noise when driving then it’s usually sticking, so yes, that’s not good. It can cause a slight sound that sounds like a scraping noise.
And it can be known to have phantom DTC’s, caused by another component. The EGR isn’t too difficult to change, just a bit of a pain, but the EGR isn’t that cheap which isn’t so good. ![]() A quick google comes up with this: ![]() Click image to enlarge Do you have a pic of the airbox damage? Mine also has a little bit of damage on the edge, but, as long as there is a good seal that’s all that matters especially on the lid as that is unfiltered air ingress and there should be no air leaks at all beyond the air filter. The filter lid, must have a perfect seal upon the air filter seal the lower air box isn’t quite so important. The lid of mine has a little piece cracked off of the edge of the lid, the seal is fine so I’m happy with leaving it as it’s all sealed. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Thanks, I already have the new egr, just could not fit it last time.. will have to try again.
I do not have a picture, but those two things that are supposed to seal the back part are broken, only the 2 "front" clips are holding it closed. ![]() Click image to enlarge And no, I do not hear anything directly from the EGR, not even the self cleaning once turning off the car. Making my Defender great again. (Or trying to at least xD) |
