![]() | Home > Puma (Tdci) > Wet / frozen Air Filter P0101 DTC |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1298 ![]() ![]() ![]() |
I would think since this is incidental with the weather, the cheaper option is to have a spare air filter, you could even just keep the old one inside to let it dry out and rotate them out..
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 736 ![]() ![]() ![]() |
Check that the drain bung is clear. Often block with leaves.
piechipsandpeas Member Since: 12 May 2021 Location: Albany, Western Australia Posts: 232 ![]() ![]() ![]() |
The cyclone piece on the entry to the airbox is designed as a water separator. I know a lot of owners have removed it to improve ariflow but not sure how effective it is as a water separator or if removing it increases the likelihood of a wet air filter.
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5986 ![]() ![]() |
Driving in high levels of spray such as motorways I’ve always found soaks the air filter on the standard air intake. Keeping the cyclone will help with this, not cure but will help.
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 691 ![]() ![]() ![]() |
Just updating this post as think I have got to the bottom of it and wanted to help anyone else with a stubborn P0101 code. I couldn't find any reference to this being a cause when searching the net for solutions.
My engine light started coming on more and more often so gave up and took it to Airley Motors who are a diesel specialist in Aberdeen. After a smoke test and then detailed diagnosis using their latest computer they spotted that the air intake temperature sensor was showing a constant -40C. On the 2.2 this is the sensor on the left hand side of the engine in the metal bit of the intercooler hose going to the air intake manifold. This was replaced and problem solved. For good measure a new MAF was fitted as was still on original after 12 years and 121k. Finger crossed this has it sorted. Certainly ran fine on way back from the garage. Last edited by Scotm on 20th Jan 2024 10:15am. Edited 1 time in total |
Thanks for following up and closing with a conclusion
Some good troubleshooting from the garage side. Frankly not spectacularly complicated, but poor diagnostics and standard parts canon approach is more than often the the case. Looks like you have a good garage there |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20939 ![]() ![]() |
I’ve never had an issue with damp filters and have the cyclone removed, I have the pipework sealed but the drain open at the base of the air box so water can get out.
Yes, it defeats the point, it could be sealed right up as well all the same, but, I don’t intend on wading many ft deep in water regardless. If you seal up the entire system with no drain left, you could end up filling up the air box with water… In particular by drawn I condensation and water spray and build up into a puddle or more in the air box base. In the location of the air box drain hole, an IP68 removable drain plug would be nice. Something that you could carry with you if needed and easily take out the rest of the time. Bearing in mind this is the factory air box and pipework I’m talking about here which isn’t ideal for sealing up anyway. The nugget stuff system is better for that I would imagine, but isn’t something I see much point in getting myself though I don’t doubt it is good. Before I got the Safari snorkel, I always found the air filter to be much dirtier with the factory air inlet and more damp. I’ve never had a single nuisance DTC come up with it either. The issue in my option is the location of the factory air inlet is very exposed to extremely water ridden air and mist spray, it draws it in and with deep water other traffic can splash that right up the side. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
