![]() | Home > For Sale & Wanted > [Wanted] Td5 defender ECU.... NNN500020 |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1652 ![]() ![]() |
i have 2 ecus on the shelf
both mapped for a td5... both plug and play (although they are better if you code the injectors in to them) |
Les Brock Member Since: 20 Mar 2012 Location: Stroud, Glos Posts: 186 ![]() ![]() |
I have one in Stroud Buddy
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6199 ![]() ![]() ![]() |
Thanks both. I will let the chappie know.
Are they both NNN500020 ones? How much are you asking (PM me if its easier, no problem) Thanks ![]() ![]() |
Ale90 Member Since: 13 Jan 2024 Location: Guildford Posts: 38 ![]() ![]() ![]() |
Hi, I’m in desperate need of a defender td5 15p ECU. Would anyone by any chance have one available?
Many thanks, Alex |
Welshsurferdude Member Since: 23 Feb 2012 Location: Newport Posts: 2493 ![]() ![]() |
I have a ecu on the shelf but I’m away in Tenerife so can’t check the numbers for 2 weeks 2011 Santorini Black USW XS.
2015 Discovery 4.5 Black pack Firenze red XS |
Ok thanks, have a great holiday!
Chris86 Member Since: 15 Jul 2014 Location: South Yorks Posts: 798 ![]() ![]() ![]() |
Dan at Storm Tuning usually has TD5 ECUs in stock on the shelf, tested and ready to go out.
01144 031303 Last edited by Chris86 on 1st Mar 2025 8:21am. Edited 1 time in total |
Thanks very much for the responses. I’ve now found one. From eBay locally but needed it quickly and it seems fine.
