Home > Maintenance & Modifications > Erratic Temp Guage
SimonMB
Spain
Erratic Temp Guage
Hi
A few months back I bought my first Defender TD5 110 2004. I'm slowly sorting out all the niggles but am struggling with erratic temp Gauge and no cabin heat.
It seems like as the thermostat opens the needle flicks into the red and truck goes into limp mode for a second or so. Needle then backs off but still reads high temp. After some time driving / idling the needle will settle back down to just left of centre. Sometime the needle just backs to the 'off' position
When I turn the truck off I can hear what sound like big air bubbles in the cooling system running down from the heater box.
Both lines to the heater box are warm and the flap seems to be working fine
Do you think that bubbles in the cooling system could be causing some of issue? I presume the issue is also electrical.
I have looked a the temps sensors and the wiring seems okay and not chaffed around the front of the motor
Looking from some guidance on what to check
Thanks
Post #1020926 12th Jan 2024 2:39pm
landy andy
You have a coolant issue if you have air in it.
The temp gauge isn’t a real reflection of temp, like most these days it’s controlled by the ecu. So works like a “proper” temp gauge up to about half way, then if the ecu detects an over heat, will immediately go straight to the RED.
Possible you just have air in system such as heater matrix, but could be another issue such as failed head gasket. Are you loosing coolant at all?
Post #1020933 12th Jan 2024 4:08pm
SimonMB
Spain
Thanks,
Yes I noticed some coolant loss today. It seems like it came from the top of the bottle. Cap was tight but maybe not sealing correctly.
I suppose no heating in the cabin also points to something coolant related.
But also odd the gauge goes completely dead sometimes
I’ll keep investigating…
Post #1020949 12th Jan 2024 8:14pm
jimbo55
The heater matrix can be a pain to bleed, I ended up loosening the clamp on the return to try to make sure the matrix was full of coolant and not air
May be also worth checking the connections in the dash to your speedo and temp gauge, the speedo damps the temp gauge in a td5
Post #1021011 13th Jan 2024 12:49pm
Martin
Site Admin
Speedo doesn’t get involved with temperature gauge. Fuel gauge yes, not coolant.
The sudden jumps could be a loose connection, either at ECU or cluster pack end.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1021015 13th Jan 2024 2:08pm
Mo Murphy
The speedo only modifys the temp gauge reading in ROW vehicles that were 300tdi vehicles built in the time of the TD5 with TD5 dashes.
50 Shades of Pennine Grey
Post #1021037 13th Jan 2024 5:23pm
