Home > Puma (Tdci) > Starting Issues (Fuel Pressure?)
Page 2 of 2 <12
Part number is LR006865, a cool £370 or thereabouts (note my comment above).
Post #1020883 12th Jan 2024 12:26am
Zed
I remember looking a while back when I did mine, typical ripoff mark up from Land Rover. Denso or genuine Ford were a fraction of the cost. WARNING.
Post #1020893 12th Jan 2024 8:42am
Ianh
This topic is worth a read, it covers PRV replacement, however in the end it seems it was not a PRV but VCV issue.
https://www.defender2.net/forum/topic80592.html?highlight=prv
Post #1020916 12th Jan 2024 1:18pm
hank
Unclip the fuel return hose off the back off the PRV then crank it. If the PRV is spewing fuel then it's gone and needs replacing (it is a friction fit ball bearing that pops out so not resettable)
I am inclined to agree I would change the VCV again for known genuine trustworthy one (read here https://www.defender2.net/forum/topic85644.html)
Read my post here about a costly wild goose chase that turned out to be a VCV https://www.defender2.net/forum/topic53240-245.html > 110 XS Double Cab
Post #1020925 12th Jan 2024 2:21pm
khamuul
Germany 2007 Defender 110 Puma 2.4 SW Tonga Green
You could try febi bilstein 46366 for the PRV/OPV/PLV/howisitcalled. (~90€ online)
Workshop manual says:
Quote:
The pressure limiting valve opens at a fuel pressure of approximatly 2000 bar. It serves as a safety device in the case of malfunctions in the high-pressure system, preventing damage due to excessive pressure. The valve operates as a disposable unit and must be replaced after a single trigger, as the valve can no longer be guaranteed leak-free.
"faulty VCV" = "malfunctions in the high-pressure system"...
Post #1020930 12th Jan 2024 3:49pm
hornet
Re: Starting Issues (Fuel Pressure?)
DuncanS wrote:
Hi all.
I'm not sure if this is as a result of depressurisation on the high side, or something else, but it drives as fine as it usually does (another story) and usually restarts fine, although sometimes can briefly reoccur even after a short period of being off.
Duncan
This erratic behavior actually points to the VCV. Possibly also the crankshaft sensor.
Post #1021788 19th Jan 2024 6:04pm
The VCV does cause very erratic behaviour, I do know for a fact that my last one was killed of by moisture or some water in fuel…
I know because I used a fuel station I have never used since as a one off, after filling up there a couple of days later it cut out after being started multiple times and things like that.
It was definitely after filling up at that fuel station, and a new VCV and fuel from another fuel station cured it.
I used up most of the fuel with the old VCV first, but there must have been water in the diesel, that I do know as a fact, and it killed the VCV. Rolling Eyes
Probably leaky old underground forecourt tanks I expect. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1021791 19th Jan 2024 6:13pm
Page 2 of 2 <12
