Home > Maintenance & Modifications > Diff/Transfer case oil - EP80/90 GL4 or GL5
Page 2 of 2 <12
Mo Murphy
So what's so good about swepco ? Is it that its just reassuringly expensive ? What unexpected noticable difference does it make over more inexpensive brands ? Likeomg, you seem to have had a favourable experience with it, how has it worked better than others ?
Please share your experiences guys.
50 Shades of Pennine Grey
Post #1020088 4th Jan 2024 11:55am
MK
Defenetly way diiferent from a typical 80W-90
 Puma 110" SW
Post #1020091 4th Jan 2024 12:12pm
Zed
Mo
I’ve been using Swepco for a few years now and will continue to do so as it was recommended to me but ’reassuringly expensive’ is a fair description. WARNING.
Post #1020093 4th Jan 2024 12:46pm
Mo Murphy
Thanks MK, what exactly is that telling me about how it's better than other oil ? Sorry, I don't know much about oil properties !
Post #1020095 4th Jan 2024 1:16pm
MK
I do not know if it is better, but both viscosities (at 40 and 100C) are way way lower than a typical 80W-90 (let´s say 20 and 150 cSt vs 7.19 and 37.9 cSt). So it is something radical, different testing method or there is a mistake in their publication. I cannot tell. Puma 110" SW
Post #1020097 4th Jan 2024 1:37pm
Mo Murphy
Interesting ! But could lower viscosity not be a bad thing ? Surely then it's acting like a less viscous grade of oil than the recommended ? Could the same thing not be achieved by just putting cheaper thinner viscosity oil in there in the first place ?
It certainly seems to be a minefield and I'm unconvinced that Swepco oil is worth the additional expense especially as it appears to act like a grade of oil not recommended and so could be detrimental !
I'll continue with Ashcrofts recommendations.
Thank you gentlemen for your thoughts.
Post #1020100 4th Jan 2024 2:08pm
Dinnu
What makes one oil better than another?
I think to the normal user, primarily would be the sound an engine, or since the subject is about gear oil, a diff would make. In case of a gearbox, you would add the easy of gear change.
When the LT77 was released, Rover specified ATF for ease of gear change. Its not because its was a better oil to protect bearings, synchros or gears!
And as mentioned earlier, what warranted a change if viscosities in pre and post Td5 LT230s Laughing Perhaps that extra 0.001mpg? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1020101 4th Jan 2024 2:18pm
excossack
Ashcrofts suggest a EP80/90 oil. I did ask if a GL4 or GL5 spec and the answer was EP80/90. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #1020102 4th Jan 2024 2:26pm
MK
You can get EP80W-90 in GL4 or GL5 flavors. All depends on the concentration of sulfur content. GL5 has about the double of such EP additives. Puma 110" SW
Post #1020103 4th Jan 2024 2:31pm
excossack
I did spot GL4 and GL5 spec. I think it will be GL4 for transfer case and GL5 for the front diff. 1999 Defender TD5 110
Regards
John M0VAZ
Post #1020104 4th Jan 2024 2:36pm
Likeomg
Sorry for the late reply,
Gearshifts are a lot smoother for me, my gearbox is only about 25 - 30k miles with a short shift and bowler gearstick and it's a nicer experience shifting now.
Diffs with the winchester ATB setup i had, previously there was some noise but since making the change it's a lot more silent.
Post #1020133 4th Jan 2024 6:18pm
LR90XS2011
Dave from Ashcrofts told me this was OK for his ATBs in defender axles
"Castrol Axle EPX 80W-90 Mineral Car Gearbox Oil GL5"
so that is what I have been using with no issues DEFENDER 90 TDCI XS,
Post #1020153 4th Jan 2024 9:01pm
MK
It turned out the published specs from the reseller are wrong.
I can post the specs sheet if it is allowed by the forum.
Mo
 Puma 110" SW
Post #1020208 5th Jan 2024 12:30pm
excossack
In the end I went for Comma GL4 and GL5 oils. Cheers for assistance one and all. 1999 Defender TD5 110
Regards
John M0VAZ
Post #1020326 6th Jan 2024 7:06pm
Page 2 of 2 <12
