Home > Puma (Tdci) > Engine failure?
SJM2018
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Aintree Green
Engine failure?
Hi all,
Yesterday I noticed a burning smell when out in the defender (2011 2.4 with BAS remap and EGR delete).
I drove for 30 minutes, parked for 15, and then I could smell burning on the journey home. The engine was up to temperature for the journey home, there wasn’t any smoke and no difference in power - so assumed the smell was coming from outside.
Today I started the defender (no problem starting); but it was running really rough (engine shaking) with lots of white smoke that smelt strongly of burning.
So I stopped it, checked for fault codes (none), cleaned the map + maf.
When I restarted, the rough idle had gone, but it was still smoking and smelling of burning.
I then took it round the block and the white smoke stopped, but the exhaust gas still smells strongly of a nasty burning smell.
Oil level is stable and no evidence of coolant in it.
Coolant is a little lower, but then the engine is still warm so will double check.
What else could it be? Split pipes? It doesn’t sound like a VCV failure?
Stu 2011 CSW XS 90
Post #1019980 3rd Jan 2024 4:54pm
SJM2018
Further checks:
Coolant level normal once cool and no bubbles in it when engine running;
In torch light, smoke seems more blueish;
When engine oil filler removed, seems to be a lot of pressure (but no smoke); and
Inlet manifold from EGR up, is covered in oil. 2011 CSW XS 90
Post #1019987 3rd Jan 2024 6:04pm
BrickBox
Injector seals blowing I’d take a guess at. Causing extra pressure and forcing oil past a seal somewhere. 2017 5.0 V8 Supercharged RRS SVR
2008 2.4 110 Utility Station Wagon XS.
Post #1019989 3rd Jan 2024 7:00pm
I’d change the VCV just in case as they aren’t expensive, are you sure there isn’t water in the fuel?
CHT sensor might be worth looking at too.
Both of these things don’t flag up a DTC, water in fuel or failed VCV because of it can cause all sorts of weird things to occur.
Glow plugs should put up a DTC if it was those, not sure about injectors but they should show the correct pressures with live diagnostics but we don’t all have access to that.
Check the air filter, and it’s pipework too.
With the weather so wet, you never know.
Wouldn’t the injector seals show signs of oil / fuel deposits around them if they were going?
I know I’ve heard they are very tricky to remove. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1019996 3rd Jan 2024 7:44pm
MK
Vote for injector seals and coolant test. Puma 110" SW
Post #1020010 3rd Jan 2024 8:24pm
SJM2018
Thank you for the replies.
Tomorrow morning I’ll remove the engine cover and have a look to see if there is any oil around the injectors.
I’ll also remove the bonnet and have a proper look at the coolant.
Finally, I’ll check the water separator on the fuel filter.
There’s a commercial injector specialist just down the road from me; they do loads of vans / commercial vehicles. So they should have experience cleaning the injector seats and replacing the seals on the Ford engines.
I added some Millers treatment and stuck some shell fuel in it earlier; but that doesn’t seem to have made much of a difference. 2011 CSW XS 90
Post #1020031 3rd Jan 2024 10:01pm
NickMc
I would stop driving it in case it has a leaking injector or the likes.
Post #1020049 4th Jan 2024 12:14am
SJM2018
So had a proper look at the coolant and it’s fine - although slightly low
Checked the water separator and there was a small amount of water in it - maybe 10 ml
Removed the engine cover and while the injectors felt solid, they were sitting in nasty oil.
Booked into a local injector specialist on Tuesday; they are going to remove and test the injectors, clean the seats and refit (if they’re ok).
Intending the replace the VCV, MAF and MAP too; they are all the original parts so 13 years old now.
Will also change the oil, oil filter, air filter and fuel filter.
Hopefully that does the trick and I don’t have an issue with the headgasket / piston rings.
 2011 CSW XS 90
Post #1020082 4th Jan 2024 11:39am
MK
Not always possible, but I have the chance to stay looking at the screen while they check the injectors. Puma 110" SW
Post #1020087 4th Jan 2024 12:53pm
hank
Those injector seals are gone so you're taking the right course of action.
Use genuine/high quality copper washers - the cheap ones are copper coated steel and don't compress/squish and subsequently don't achieve a seal.
If your injectors are found to be faulty my advice (learned the hard way) would be to buy brand new genuine Denso replacements. Stay away from reconditioned/remanufactured. Why do I say this you ask??
 > 110 XS Double Cab
Post #1020092 4th Jan 2024 1:45pm
NickMc
Yes don’t waste you time with recon injectors on these! I buy them from Merlin Diesel Specialist.
I wouldn’t go swapping all the sensors, as you can cause yourself more problems, again buy genuine or quality, cheap sensors and aftermarket are a nightmare.
Post #1020112 4th Jan 2024 5:08pm
MK
Once I´ve got a "Hella" boxed MAF. It was a total joke. Puma 110" SW
Post #1020113 4th Jan 2024 5:11pm
NickMc
Yes plenty of counterfeit parts out there especially on eBay,
Post #1020123 4th Jan 2024 5:50pm
MK
That time I could tell because of the terrible finish of the piece. However with the VCV is a lot more difficult or rather impossible. Puma 110" SW
Post #1020124 4th Jan 2024 5:53pm
SJM2018
Had an update from the garage:
Injectors tested ok, so they suggested sticking them back in;
Two glow plugs dead, so having the full set replaced; and
Compression test ok - cyclinder 4 was lower at 320 (others we 350-380), but they said it got there quick and held compression fine.
So hopefully cleaning the seats and replacing the injector seals, should do the job.
Kind regards
Stu 2011 CSW XS 90
Post #1020699 10th Jan 2024 11:42am
