![]() | Home > Maintenance & Modifications > Which amp |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20971 ![]() ![]() |
If you are looking for an active Amp/Sub combo, that’s relatively easy to wire and mount I’d take a look at a Kicker Hideaway.
Its design imho fits in nice with the Defender, a WRMS true to spec rather than some of the others out there. There are a few that spec 1200w for example but rated wrms is more like 150w. ![]() ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Lightwater Member Since: 28 Jun 2020 Location: Sydney NB Posts: 75 ![]() ![]() |
Recently I re-glued my Wharfedale E50 speaker spiders, replaced the capacitors, & did internal cabinet bracing with dowels while at it with an excessive amount of 24 hour Arildite. Speakers bought new in the early 1980s. What an improvement. No one issue was a major improvement, but as an overall repair/maintenance issue fix. Well worth the effort.
You can't turn vinegar into Grange Hermitage, but with a bit of maintenance on basically quality products to start will, you can get a pretty reasonable setup. Go for a quality subwoofer & while at it upgrade the wiring. The best thing you can do is stuff the car full of acoustic insulation to reduce background noise levels, spoken about a number of time on your Defender forum. Freelander acoustic insulation link: https://www.freel2.com/forum/topic33026.html 25mm to 50mm minimum acoustic foam, including roof, it does make a vast improvement, throughout the vehicle to improve sound level issues is my recommendation. Visitor - Freelander owner |
LandymanStefan Member Since: 30 Aug 2017 Location: Surrey Posts: 886 ![]() ![]() ![]() |
Depends on your budget, I had a cheap alpine amp for many years and was never that impressed with it. I upgraded to an alpine pdx-v9 and it was absolutely game changing. Compact and can power a massive system all from one small box. I have mine mounted to the lower part of the bulkhead powering 4 speakers in the back (parallel mounted) 2 100w components in the dash and a 600w subwoofer.
Poulstonb Member Since: 30 Jun 2022 Location: Styal Posts: 88 ![]() ![]() |
If I just install an amp will I get better sound out of the speakers i already have .
Cant remember the brand but paid £150 a pair so not cheap ones |
Yes it’s very likely, often the aftermarket head units in built amp is advertised as having 4x50w outputs however this is a peak power not the rms power which matters. The rms power will be much lower which means at higher volumes the head unit will distort or clip the sound quite quickly. Most aftermarket speakers are rated for 50w rms power each so if you got an amp to match that with 50w rms outputs you’ll be able to increase the volume more without distortion/clipping. At lower volumes the difference will be small but when you start increasing it to be able to hear the stereo on the motorway it’ll make a difference.
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2677 ![]() ![]() |
Depending on budget i'd get a Hertz Hdp5
Can power all the tweeters and a sub, I currently have a Hertz HDP1 powering a 15" SX 380D sub and a HDP4 powering focals front and rear it's really quite impressive. a HDP5 would probably be more than enough in a defender, when i turn up all the gain, anything more than half way on the stereo is painful. |
