![]() | Home > In Car Electronics > Mud stuff TDCi switches. |
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 998 ![]() ![]() ![]() |
Hi
Its a 50/50 question but logic would say "Yes" Jim |
Rescue01 Member Since: 17 Jul 2015 Location: Aberdeen Posts: 106 ![]() ![]() |
Thanks Spock
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6038 ![]() ![]() ![]() |
If you use a multi-meter in continuity mode and check pins 1 and 4 and you get either continuity with the switch pushed in or out then you will know which pins are which and work out the rest from there? 1999 Defender TD5 110
Thanks for that.Electrics is not my strong point
If they are like the other TD5/TDCI switches Mud sell then with the switch facing away from you but the right way up the pins go left to right (1-4). On these there is also one silver pin which is the earth pin and number 4.
These switches - https://www.mudstuff.co.uk/collections/mud...ront-light Just looked again the AUX switch you linked to is like the above with 4 pins, not 5 as in the document you attached with the wiring diagram which is for genuine switches. |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2243 ![]() ![]() ![]() |
MUD switches are simple to wire
Pin 1 -Power in Pin 2- Dashboard Illumination in Pin 3-Power out Pin 4 (Silver pin) -Earth/Ground. 02' 110 TD5 Double Cab Rebuild Thread |
Thanks for all your feedback. All sorted
