Home > Maintenance & Modifications > Leaking EGR blank
Inguz
Leaking EGR blank
Hi all, I've blanked my egr a couple months back and it's been leaking since day 1. I've used hi temp sealer a couple of times with no success.
The sealer is only rated to 350c. I want to try a higher temp sealer and see will that work.
What I would like to know though is it ok to use a cement, as everything I can find rated to a higher temp is cement and not silicone.
Post #1019273 26th Dec 2023 10:24am
Ianh
Permatex 27038 Optimum Red RTV Silicone Will go to 399°C.
I would not use exhaust cement as that breaks up and turns to fine dust and you don’t want that getting in the engine.
Worth checking out products for stove / log burner sealing in addition to automotive sector sealants but I think the high temp 1000/1300 °C ones are cement based as well.
Post #1019369 27th Dec 2023 3:07pm
Inguz
I think the temp may get higher than that and it will keep blowing out.
I was worried about the cement just crumbling. It doesn't seem like there is anything on the market that will work.
I used the kit from paddocks that doesn't have the gasket for the exhaust manifold. I may try another kit that has the gasket.
Post #1019372 27th Dec 2023 3:20pm
Ianh
A gasket will be better in this use case. I’ve used the permatex on exhaust slip couplings but they were further downstream of the engine exhaust manifold and therefore the temps were lower.
Post #1019373 27th Dec 2023 3:22pm
bankz5152
You need exhuast putty/sealant. That manifold can hit 500c+
Post #1019387 27th Dec 2023 6:42pm
Inguz
I see permatex and muffler tailpipe putty is rated up to 1000c. Would this work? I’m mostly worried about it breaking down and ending up in the turbo
Post #1019392 27th Dec 2023 8:38pm
NickMc
What engine is this on? If it’s td5 there is a gasket available.
Post #1019398 27th Dec 2023 10:15pm
Inguz
Ye it’s a TD5. I’ve seen the gasket in some kits but not the one I got. I can’t find it separately. I may buy another kit with the gasket included.
Post #1019402 28th Dec 2023 4:19am
jim4244
England 2013 Defender 90 Puma 2.2 CSW Fuji White
Buy a sheet of this and cut it out to size?
https://www.ebay.co.uk/itm/264095421643?ha...UIbJq-qVYw
Jim
Post #1019403 28th Dec 2023 5:20am
Inguz
That's a great idea, I just wonder does it come in a higher temp rating. It says 440c short term. I spend a lot of time off road and mountain roads, I may be more long term at that temp, but still looks worth a shot
Post #1019404 28th Dec 2023 6:13am
