Home > Tdi > Coolant Loss but how much? |
I would suspect 2/3rds to 3/4s full and get that cap sorted ASAP The Iveco one with the hose bayonet is an excellent cap.
3rd Dec 2023 10:41pm |
MattH268 Member Since: 01 Dec 2021 Location: Moray Posts: 64 |
Thanks for the reply, I'd seen posts about the Iveco cap, but it seemed to be for TD5 & Puma not 300tdi & I didn't know if all of the header tanks used the same cap? I was going to order the NTC7161 stock cap that's been on the vehicle for a good while, but I'll see what I can find. 300tdi 90 CSW
2.2tdci 110 HCPU 1972 Series 3 88" Truck Cab |
4th Dec 2023 8:12am |
I could be wrong but I thought the caps were interchangeable between the 200/300/TD5/TDCI. Appear to be the same thread pattern anyway.
4th Dec 2023 8:17pm |
All sorted, topped up with the same red/pink coolant, new rad & thermostat O-rings and a new stock cap. The expansion tank cap on my 2.2 is much smaller than the cap on the 300tdi so at least 2 different types.
Also just repaired the heater duct with a new seal and lined it up as it had about an inch gap hopefully it gets more airflow now! M 300tdi 90 CSW 2.2tdci 110 HCPU 1972 Series 3 88" Truck Cab |
26th Dec 2023 6:14pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19651 |
Take a look around the radiator, coolant hoses and connections whilst you are there, a minor leak under pressure can be a small leak only.
Also the water pump too, especially the edge nearest the floor for coolant traces usually dye can be dry or just a drip. You can sometimes get just a very small leak that only loses a very small amount of coolant when hot, and under pressure, then dries up. Typically just a little top up of coolant once or twice a year, I find is normal. But more than that, more than 1L in a year or having to periodically add more every month or two, usually there is a minor leak. And from there will usually get slowly worse over so many more months after that, mid winter is usually when it can occur due to temperature dropping and more excessive expansion and contraction just due to the normal changes in outdoor temperature. A good coolant usually keeps things in good order, I replaced mine (the coolant) a couple of years ago but, itβs got a long life on modern coolant manufactures. Diesel$ Live$ Matter. β½οΈπ’οΈπ¨βπ§π§°βοΈ RED, WHITE & BOOST! π¬π§ |
26th Dec 2023 10:23pm |
Duly noted to check when driven again. My 300tdi hasn't been used in the last few weeks but I'd not really had the chance to fit the new expansion cap & seals which I knew were damaged and where all of the coolant had collected around. 300tdi 90 CSW
27th Dec 2023 10:19am |
