Home > Off Topic > Ghostbusters
Screbble
Ghostbusters
Well…
I’ve got a list of nice little jobs to complete over the festive break - but this wasn’t one of them ☹️
Just noticed this as I pulled up at the local shop. Driveway is clean so it must have happened ‘en route.’
Thankfully that godawful (festive?) colour and general location tells me it’s nothing serious and that it’s looking like the tank or pipework associated with the windscreen washer.
I haven’t got time to look properly today, so in the meantime, any likely/known areas of failure?
Merry Christmas 🎄
Post #1019063 23rd Dec 2023 11:51am
Mr Fox
United Kingdom 2015 Defender 90 Puma 2.2 HT Keswick Green
Can't help definitively BUT I have to commend you on the thread title - brilliant! Mr. Green
From a layman's perspective, I would have suggested that was coolant or antifreeze.
Unless your mix of windscreen washer is almost pure and unmixed with water, I'd say it isn't that but I could be incorrect.
Post #1019069 23rd Dec 2023 1:02pm
Screbble
Thanks Mr Fox.
The colour and location makes me want to optimistically focus on the washer system rather than the coolant system.
Still haven’t had chance to have a closer look but will probably do so later.
I hope it is a ‘cheap fix’ - something like the washer pipe coming off the pump…
Fingers crossed 🤞
Post #1019074 23rd Dec 2023 1:17pm
BuckBlu110
United Kingdom 1994 Defender 110 BMW M57 3.0 Diesel CSW Buckingham Blue
It depends what coolant you use, maybe check the colour of your screen wash and coolant and see what matches and take it from there. I’d say if it was coolant, then it’s likely to be heater matrix related, pipes or even the matrix itself.
If it’s screen wash, then it could be a pipe or non return valve that’s bust as both are under the wing on that side.
Post #1019076 23rd Dec 2023 1:24pm
Screbble
Well…
Had a closer look and noticed that the ‘new’ non return valve had fallen apart.
Fortunately I had a spare (I know I could have simply removed it).
Washer tank full and no leaks.
Not very often I have much luck so hoping that was it 👍
Post #1019103 23rd Dec 2023 6:05pm
Procta
That green liquid looks like Hydrolastic fluid from metros etc. Shocked Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #1019109 23rd Dec 2023 6:36pm
Screbble
Crumbs that’s a blast from the past Procta.
My cover has been blown - I fitted Metro subframes and suspension…
It’s a horrible colour - reminds me of Del Boy’s paint 🤪
Post #1019116 23rd Dec 2023 6:54pm
lohr500
Relatively speaking, a good result Thumbs Up
I was thinking it might be a leak from the heater matrix given the bilious green colour which I thought could be anti-freeze.
Post #1019117 23rd Dec 2023 7:07pm
Procta
you sure its not off MGF stuff Whistle
also about 8 years ago procta here was playing with metros Very Happy All the fluid was deionized water and antifreeze. Something to do with selling the cars over a broad Laughing Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #1019125 23rd Dec 2023 7:56pm
I always wondered what ectoplasm looked like.
Post #1019131 23rd Dec 2023 8:20pm
Screbble
Yes indeed.
There are many seemingly paranormal ‘goings on’ associated with Defender ownership.
Post #1019158 24th Dec 2023 10:39am
seriesonenut
One of my former Defenders had 666 marked on bits of interior trim clearly part of the original build sheets etc. If it was the work of the devil all I can say is thank you. It was the most reliable vehicle I have owned! 1984 One-Ten CSW
2010 XS USW (sold)
1957 Series One 88 diesel
1958 Series One 88 4x2
1990 Defender 200tdi CSW (sold)
1989 Land Rover Ninety (sold)
1998 Discovery 2 (sold)
1995 Discovery 1 (auto) (sold)
1990 Discovery 200tdi (sold)
1987 One Ten CSW turbo diesel (sold)
Post #1019170 24th Dec 2023 11:46am
Screbble
They say the devil is in the detail so clearly he did you proud 👍
Post #1019175 24th Dec 2023 11:57am
Screbble
Well…
It was MOT day today, and can you guess what happened as I drove off on that terrifying journey.
Yes, non return valve number 2 decided to give up.
Thankfully, and as many of you decided to do many moons ago, I simply removed it and connected it ‘straight through.’
It’s as if my Defender knows it’s going somewhere it doesn’t want to be. Last year my ABS modulator failed on the day of the MOT.
Most importantly, it was a ‘pass’ today with only one minor advisory (not the washers!).
Need to think about whether I fit an ‘enhanced’ NRV or just titivate my last-minute botch up this morning. 🤪
Post #1023331 2nd Feb 2024 4:10pm
L110CDL
Well done with passing the mot Thumbs Up
Having a good long think will let you know which way to go on this Very Happy Clayton.
Keeper.
Post #1023378 2nd Feb 2024 10:52pm
