![]() | Home > Puma (Tdci) > The coolant loss conundrum |
hornet Member Since: 04 Jan 2010 Location: Western Europe Posts: 373 ![]() |
If nothing is obvious, I wouldn't mess around for long and arrange for a pressure test of the system, ideally you can see where the coolant is leaking. There are so many possibilities.
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2414 ![]() ![]() |
Re the EGR cooler, you could remove the two coolant pipes and join them together , that would prove if it’s the cooler , and as your EGR is blanked it should not cause any issues.
Note the 2.2 does have issues with cooler leaking, whereas it’s rare on the 2.4. Also have a look at the heater valve as well, it may be dripping when set to hot and engine is warm. Worse case it is a head gasket, over the last few months there have been several topics on water loss and it has been the HG, yet like you there were no other tell tale symptoms or positive RELD tests. |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1652 ![]() ![]() |
if its losing that much water and it not coming out and going on the floor you aint doing the old girl no good.
get it pressure tested at a workshop as soon as you can and hopefully its a simple thing and not a head gasket or egr cooler fail |
RFT Member Since: 13 Nov 2010 Location: Yorkshire Dales Posts: 691 ![]() ![]() ![]() |
My 2.4 MY10 at 120,000mies started losing coolant exactly as you described, one new water pump later and all is mended now. 130 Puma HCPU with an Artica 240LR Demountable Camper
neirbossor Member Since: 10 Jun 2021 Location: Aberdeenshire Posts: 23 ![]() ![]() ![]() |
Thanks, I have ordered the blanking plate for the exhasut side, hopefully be here before I need to run it again. I will do a run with that installed and if that doesn't fix it then pressure test it is I guess...
Was there a visible leak from it? |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 2020 ![]() ![]() ![]() |
had the same issues 2010 2.4, i bought a kit from Dr head gasket as recommended on here to test for exhaust gasses in the coolant, at first it passed the test but once driven for at least 40 mins and up to normal running temp the fluid would turn yellow
![]() ![]() ![]() ![]() 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
Urgh...so blanked off the other side of the EGR..no change! I have ordered a coolant pressure tester hanging on to the last thread of hope that its an external leak that only manifests itself when I'm not looking.
If that doesn't show anything then looks like its the head/head gasket, really the last thing I wanted to deal with. Probably just as well replacing the whole head for the price of having to do that job twice should it be cracked. I love the landy but its testing my love. |
So, got the pressure tester today, filled the system up and pressurised to about 15psi..and found the biggest coolant leak, spraying out of the oil cooler blanking plug out of the back of the water pump. Looks like a crack on the seam at the top. Strange how I didnt identify this on any other occasion..so its either the cause of my original leak or I have burst it during the pressure test. I have ordered another but no hope in getting it here before 2024, so will be off the road till then.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17842 ![]() ![]() ![]() |
That's a very common source of leakage.
As it’s just a hose blanking end cap it may be worth measuring the Inside diameter of the existing one,or spigot diameter on pump and doing a search for silicon blanking cap. you will find a lot from auto spares suppliers, then see if they have one of the correct size and can get it to you next day or in next couple of days.
It will likely be better quality and cheaper than a LR one. |
As the Land-Rover part is a shocking £103 you might also want to take a look at this thread:
https://www.defender2.net/forum/topic87744.html I found some sensibly-priced alternatives. |
Not when I looked under bonnet, but once on ramp in garage with cold engine they spotted it on start up 130 Puma HCPU with an Artica 240LR Demountable Camper |
Thanks all, I opted for the s*itpart one as I could get it dispatched yesterday, super expensive for what it is , especailly when it doesnt need to exist in the first place.
