![]() | Home > Maintenance & Modifications > td5 manifold |
| tolley Member Since: 07 Nov 2011 Location: gloucester Posts: 1125
what is the best fix for the td5 manifold warp before it happens
| T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101
Have a spare for when it does?
| Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505
Remove the webs between the ports , it allows it to flex more.
any photos
| Steve B Member Since: 22 May 2009 Location: Warwickshire Posts: 589
This Also open out the holes to 10mm except the center 2. I also made spacers to allow me to fit longer high tensile bolts, these will stretch and maintain the clamp load. IRB Developments will do you a skimmed/blasted and opened out manifold. This is where I got mine from. As mentioned some people remove the webs but I didn't. Steve ![]() |
| AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3711
Replace the 8mm manifold to head bolts with 10mm 130's have feeling's as well you know
| derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 567
when mine warped i got a ceramic coated one from td5 alive and a set of JE engineering studs and spacers but i noticed the gasket was blowing 11months later,so i took it off and found the manifold was warped again, so i sent it of to the local machine shop and had it skimmed (my guess is the ceramic one was a good one that hadent warped when it was coated) and upto press there is no signs of any blowing
For normal use id say have the manifold skimmed and fit a JE stud kit open the holes to 10 mm (except the middle 2) then it should be ok Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
| abomb1969 Member Since: 23 Jul 2011 Location: Welwyn, Hertfordshire Posts: 79
Can I ask what to look for, gasses blowing?
| GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387
Signs of soot is the main visual. QRZ M8VPF
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
The first sign is usually a squeaking or whistling noise, which is the gases escaping under pressure. Darren
