Home > Puma (Tdci) > P0101 Fault HEADACHE
nufc1ac
United Kingdom 2014 Defender 110 Puma 2.2 USW Zermatt Silver
Hi All, I’m new to the forum.
I’ve got a 2014 2.2 puma with stage 2 bowler upgrade.
Car has been at a local specialist garage (do lots of defender rebuilds) with P0101 fault code. Checked the usual culprits and on doing so found about 1l of water in the intercooler. I hadn’t taken the car in deep water. Drained out and dried and no air leaks noted. Still going into fault but strangely doesn’t happen when air filter is removed. Changed to silicone hoses and some new seals in throttle body to no effect.
They (and everyone they have spoken to) are running out of ideas.
Not sure whether the water was an incidental finding / red herring or partly responsible, but still worrying nevertheless about how it got there!
Main point now seems to be that it runs fine without the air filter but goes into fault when the air filter is installed. Has anyone had this before or any idea on what may be the cause?
Post #1017409 4th Dec 2023 4:30pm
landy andy
Assume they have swapped to known good MAF and that error still occurs
Water is known to kill MAF’s.
Post #1017410 4th Dec 2023 4:41pm
andy63
I'm not going to be of much help here but I have been messing around with a few sensors on the same engine..
The water, and assuming it is pure water no coolant present I'd just check again after some use..
The mass air flow sensor can be checked with a scope to see if it is behaving as expected or has a fault on it..
It receives a 12v supply.. Outputs a digital signal for both mass air flow and air temp..
And the frequency of switching which is an indication of the flow can be checked and compared with a known good..
A screenshot of one I dis a week or so ago
Post #1017416 4th Dec 2023 5:20pm
nufc1ac
Yes I believe he has tried a new Bosch one
Post #1017521 5th Dec 2023 2:24pm
nufc1ac
Thanks, I think he was going to test with a scope today so fingers crossed!
I gather an air filter offers such low resistance so it must be something relatively minor as to why it goes into fault when the air filter is in, but not when removed
Post #1017522 5th Dec 2023 2:27pm
andy63
Hope you get it sorted.. Can't think that a good air filter would cause a fault on the sensor, but can't argue with facts.. I'm sure whatever type of air intake system you have will have been checked for any rather possible obstructions..
If they do use a scope, then a comparison between the fault and non fault set ups should show up if it is a mass air flow issue..
The likes of pico automotive give examples of what to expect from a good sensor.. 👍
Good luck
Post #1017532 5th Dec 2023 3:15pm
landy andy
Have you checked the air intake pipework is all clear, even before the air filter.
Post #1017543 5th Dec 2023 5:08pm
Ianh
As per above, it may be a blockage...or faulty sensor.
If none of the original air intake pipes after the airbox had a split then the only way water would have got into the intercooler (IC) is via the air filter. This can happen if you did a lot of driving in heavy rain and the airbox drain is blocked.
With that much water it would have saturated the filter and bits may have broken off and stuck in either the airbox to turbo hose, the turbo, turbo to IC hose, IC, IC to metal pipe, metal pipe to inlet manifold (90 degrees bend) and inlet manifold.
You said silicon hoses were subsequently fitted, so I would check the IC to see if there are bits of filter in there, and the airbox to turbo hose.
You also have to check the MAF, Air charge sensor (it’s actually an air charge temperature sensor) in the metal pipe and the MAP sensor. See this topic for details on sensor locations https://www.defender2.net/forum/topic69503.html?highlight=sensor
Ps re the sensors .- My understanding of the roles these sensors perform.
So function wise the MAF is measuring the volume of air from the filter box on its way to the turbo, the turbo is compressing the air but in doing so also heats it, so the compressed air is sent to the intercooler to be cooled and increase its density, the Air Charge Sensor is measuring the temperature of the air exiting the intercooler and heading to the inlet manifold and the MAP sensor is measuring the pressure of the air in the inlet manifold. These three sensors are providing inputs that are used with other inputs to determine and provide the optimum fuel air mixture at any specific time.
Post #1017555 5th Dec 2023 8:55pm
andy63
As I said above I've been playing with a scope to look at the maft sensor.. And while that information doesn't give an output in mass or volume it can be used to compare good and bad as the switching frequency of the output signal is proportional to the mass of air flowing..and if you have a good example of a waveform then you should be able to identify a bad sensor by comparison..
Torque however will give the flow in grams per second..
Its actually remarkably accurate if you can be bothered to do the calculations based on the known weight of air.. The rpm at any given time.. The only variable to work with is the volumetric effeciency which I took as about 90% and my engine is the 2.2l..
I was surprised that the grams per second reading on torque was approx what was calculated..
That reading of air flow in mass of air in grams per sec is the amount of air flowing.. The turbo will obviously compress it and it will occupy a smaller volume but mass of air is mass of air.. That won't change
The maps will determine how much fuel to inject given the pressure and temp etc etc..
That's basically how I see it anyway..
Post #1017563 5th Dec 2023 9:40pm
nufc1ac
Sorted (we think)! MAF sensor was the blame.
They had tried a new one in but this seemingly wasn’t the right one. Another defender of the same age was in for some work and so tried their maf sensor in and ran no issues. Same one now in mine and been running fine this week.
Fingers crossed 🤞🏼
Post #1018859 20th Dec 2023 10:08pm
andy63
Good to hear..
The maf sensor fitted to the pumas has a digital output.. On a scope the trace you get of the frequency of the switching voltage which represents the mass of air flowing is very similar to the analogue mass air flow sensors trace.. They obviously arnt interchangeable as the ecu needs to see the right one but they physically look identical I believe.., could that have been the issue with the one that was tried.. Ie wrong type..
Post #1018867 20th Dec 2023 11:37pm
nufc1ac
bad news - into fault again.
Done about 400 miles since picking it up and into fault when doing approx 70mph 2500-3000 rpm yesterday
back to the garage if they want another crack at it
land rover wont touch it as its had bowler stage 2 remap etc
any recommendations for other north east based garages if the original one draw a blank?
Post #1019359 27th Dec 2023 1:35pm
andy63
These are just some more thoughts..
How long have you had the stage two map.. I'm wondering is there any possibility there is an incompatibility between the air requirements of that map and the sensor., or the actual intake capacity of your set up not been capable of supplying what is required..
Can you switch maps back to standard and try that for a while..??
Post #1019367 27th Dec 2023 2:38pm
nufc1ac
hmm yes that is an interesting thought. If the garage that I'm using cant do that, then I've got another in mind that might.
I bought the car in august 23.
Looking through the file of paperwork.
Remap done at bowler in 2017
Raised air intake 2020 at flatdog.
Previous owner who had both bits done reports no history of any issue
(he part-ex'd and I bought it from a dealership but managed to track him down on facebook).
Post #1019370 27th Dec 2023 3:08pm
andy63
well as I said just thoughts but the map appears to have been on long enough to have flagged up issues before now..
I have read that certain upgrades are incompatible with raised air intakes..but I think they were referring to a turbo upgrade..
Post #1019375 27th Dec 2023 3:34pm
