![]() | Home > Puma (Tdci) > Hazard Lights |
hi Rich,
I've not heard of this before. Try a search on the forum Then, do you know where the flasher unit is ? Probably behind flap under steering wheel, pop the cover off and check to see if it gets warm - a good place to start. |
Nick T Member Since: 29 May 2011 Location: Bolton Posts: 203 ![]() ![]() ![]() |
My hazzards burnt out after constant use.....only joking.... 20 odd years of LR ownership and I'm still a sucker
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 ![]() ![]() ![]() |
Odd one. I have NO idea.
richuk Member Since: 13 Nov 2011 Location: Dorset Posts: 201 ![]() ![]() |
Thanks for the replies. I did search the forum but couldn't find any similar threads. I tried it again tonight and it stopped within 4 minutes. But stops in the on position not off as previously stated. The on period just gets longer until it stays on. The off period is as it should be. After it stopped I switched it off for 30 secs and then on and they were still stuck on. Then I left it for a couple of minutes and tried again when it flashed slowly before stopping again, which leads me to believe it is something to do with the flasher unit overheating, and then working again as it cools down. I will find the flasher unit and see if that is a correct assumption. Rich
semper in excretia sumus solim profundum variat |
Other than adding an unintelligent answer based on a total lack of electrics knowledge - might this be an earth problem?
RFT Member Since: 13 Nov 2010 Location: Yorkshire Dales Posts: 692 ![]() ![]() ![]() |
Four things to consider:
Do you have LED indicators as a conventional flasher struggles to cope with LEDs? What happens when you leave the indicators flashing for extended period? Is the alarm working ok, as the alarm unit flashes the indicators? Do you have trailer attached? But my assumption is that the flasher unit is flucked. Richard 130 Puma HCPU with an Artica 240LR Demountable Camper |
