Home > In Car Electronics > Defender TD5 Headlight issue |
A relay will buzz when it is not getting enough current to properly engage it. It is likely that your main light switch is faulty, not the relay. It is a very common failure on Defenders.
EDIT: Master light switch AMR6104 https://www.lrworkshop.com/parts/AMR6104 |
3rd Dec 2023 3:05pm |
Lancelot62 Member Since: 03 Dec 2023 Location: Dorset Posts: 2 |
Thanks Geobloke.
Really helpful. |
3rd Dec 2023 3:46pm |
No problem
It is an easy DIY fix if a little fiddly when getting the steering column shrouds off. |
3rd Dec 2023 3:51pm |
Just so you know:
One of the reasons the master light switch fails is because there is too much current being drawn through it and the contacts melt the plastic surround they are fitted into. This is what I mean by a known weak point. The solution, since you are changing the switch you can protect it into the future by also fitting a stand-alone headlight loom. In this way the light switch is only switching the loom circuit and there is no load on the light switch side. Nakatenenga do one and Boomslang and Red Bison. Plus a host of cheaper versions. The other benefit is that if you have the standard H4 halogen headlights fitted to your Defender (the original factory ones) you will find the light output can be vastly improved with the sand-alone loom. A two for one |
3rd Dec 2023 4:54pm |
