![]() | Home > Technical > Steering box leaks |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3600 ![]() ![]() ![]() |
I replaced mine on a bench, with the sector shaft removed, so I cannot say if exchange in situe say is doable or not. But had made a thread with my overhaul. https://www.defender2.net/forum/topic79246.html 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
PoormansXS Member Since: 21 Oct 2023 Location: Lincolnshire Posts: 63 ![]() ![]() ![]() |
Thanks I’m sure that’ll come in handy when I do tackle it. It’s not ideal but currently I’m getting by (and not losing and fluid) by keeping it off full lock. But I do want to get it out the way soon as it can’t be long before it gets worse
It is never good for the box to put in a full lock. Note that the bottom seal will see full pressure from the pump on a right lock. On a left lock not.
I think I read in the owners manual also no to keep on full lock for more than x seconds (I cannot recall the x value, but might had been 30) as would overheat the oil. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 529 ![]() ![]() |
If it was'nt a Genuine box or Adwest supplied then I would just replace it, the cheap rebuilt boxes are a liability. The bottom seal you can see above the drop arm is just a dirt seal the pressure seal is higher up inside the housing. The seals usually leak because the lower bush or shaft is worn allowing to much side play on the sector shaft.
I’ll check my paperwork and the numbers on the box tomorrow to hopefully determine if it’s adwest or not. Also to see if it was fitted new or recon.
Thanks all |
