Home > Technical > Hazard Lights Not Working After Relay and Switch Replace
Mexirican007
United Kingdom 1999 Defender 110 Td5 CSW Cobar Blue
***1999 Defender TD5***
Hey everyone,
I've been dealing with an issue with my hazard lights, and despite my best efforts, I can't seem to figure out what's going on. I'm hoping some of you might have some insights or suggestions on where to look next.
Here's the problem: my hazard lights are not working properly. I've already tried replacing the relay and the hazard switch, thinking that would solve the issue, but it didn't make a difference. The weird thing is that my turn signals work perfectly fine, but when I use the turn signals and then switch on the hazard lights, they don't function at all.
I'm stumped as to what might be causing this, and I'm not sure where to start troubleshooting next. Has anyone experienced a similar problem before, or does anyone have suggestions on what I should check next to pinpoint the issue?
Any advice or guidance would be greatly appreciated. I'm eager to get my hazard lights working again, especially for MOT reasons. Thanks in advance for your help!
Post #1016906 30th Nov 2023 9:09pm
geobloke
Well to begin with here are the wiring diagrams
https://www.lrworkshop.com/wiring-diagram/...tor-hazard
The hazard switch over-rides the indicators so that is why when the indicators are on and you push the hazard switch the lights stop flashing. It is a safety thing, if you press the hazard switch then that is more important than indicating.
The header is really important as that directs the current to the lights (ABCD).
Have you checked both fuses? There is a 10amp in the passenger compartment and a 15amp under the seat. The latter is the power to the hazards when the key is not in the ignition, if this has blown or the contacts are corroded then no power to the hazard switch and it will interrupt the indicators.
Good luck. Thumbs Up
Post #1016917 30th Nov 2023 9:38pm
Mexirican007
I just checked the one under the seat, but your diagram said Fuse 21. I only check fuse numbers 8, 19, and 20 on the diagram. All was good.
Post #1016928 30th Nov 2023 10:28pm
Martin
Site Admin
Probably the permanent (battery) 12V supply to the switch. Check fuse 7 in the seatbox fuse box.
Although I would expect other issues if this fuse was blown, like no interior lights, clock stopped and possible radio not powering up and speedo memory loss.
If the fuse is OK, then need to check at the hazard switch plug with a multimeter, for 12V on the purple/brown wire (voltage testing to a ground point).  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1016966 1st Dec 2023 10:22am
geobloke
As Martin says, plus continuity of the wires leading to and from the hazard switch. Could be an intermittent connection from a broken wire.
Post #1016970 1st Dec 2023 10:48am
Mexirican007
Thanks, I will be checking this weekend. Fuses are good, and yes I do not have interior light either. They went out around the same time.
Post #1016992 1st Dec 2023 12:17pm
geobloke
So likely a power interruption to the hazard switch and relay then. Check the contacts for corrosion. I have just had to replace the contacts in the glow plug replay base for this exact reason - Also under the drivers seat.
Post #1016995 1st Dec 2023 12:38pm
Martin
Site Admin
No, won't be the relay (flasher unit) - as the indicators work.
Since the interior lights are also not working, it's something to do with the permanent power feed to the switch, which is shared with the interior lights.
Have you checked the fuses in the seatbox fuse box - easily forgotten. Fuse 7, 20A. Check it or swap it!
Diagram link above is incorrect as it's for 2002+ model, you need these:
https://www.lrworkshop.com/wiring-diagram/defender-1999-td5
Specifically:
https://www.lrworkshop.com/wiring-diagram/...tor-hazard  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1017000 1st Dec 2023 12:51pm
geobloke
Apologies I did not mean it was the hazard relay, just the contacts within the fuse holder. Using the relay as an analogy as it is in the same location and the contacts had corroded.
Post #1017001 1st Dec 2023 12:53pm
Martin
Site Admin
Thumbs Up  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1017002 1st Dec 2023 12:54pm
Mexirican007
I am about to start the hunt. So I had already replaced the Relay and Switch. I will recheck the fuses under the driver seat again. Then I will start testing the wires.
Thank you all for the replies.
Post #1017149 2nd Dec 2023 2:27pm
Mexirican007
Specifically:
I have power to my switch and nothing. How deep should I go. I am starting to take about my lights to start
Post #1017151 2nd Dec 2023 3:44pm
Martin
Site Admin
That's pin 8, white/green wire which is the ignition feed (used for the indicators).
Is there power on the one next to it, pin 7, the purple/brown wire (permanent feed) - used for the hazards.
The lights will not be the issue as the indicators work!  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1017152 2nd Dec 2023 3:49pm
geobloke
As above. If you do not have permanent 12v to the purple wire at the switch then you should back track and check the in-line splice "A79" in the wiring diagram. Not sure why it is there, but could be the break in the feed.
Post #1017154 2nd Dec 2023 3:58pm
Martin
Site Admin
Interior lights and hazards BOTH don't work, and these two circuits are those fed from splice A79.
https://www.lrworkshop.com/wiring-diagram/...?label=A79 (page 2)
The 'in' to A79 comes from the header (joiner/splitter) C0287, pin 11.
https://www.lrworkshop.com/connectors/defender-1999/C0287
C0287 is behind the centre switch panel, and splits/joins various sets of wires, these are relevant here:
Pin 13 in from seatbox fuse 7
Pin 11 out to splice A79, then to hazard switch and interior lights
Pin 12 out to clock and speedo
Pin 14 out to radio
If fuse is OK, and clock is still working, looking at a fault between pin 11 and the splice
If fuse is OK and clock NOT working, looking at a fault between fusebox and the header  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1017156 2nd Dec 2023 4:15pm
