Home > Maintenance & Modifications > Patriot Security Tilt/Cage Fitted to my DC
MuddyMarky
United Kingdom 2011 Defender 110 Puma 2.4 DCPU Stornoway Grey
A couple of people showed some interest in the fact that I spent some of Saturday fitting my new Patriot Security Tilt and asked for some pics, etc.
As I said on the "what did you do today...." thread, it was a little challenging to fit in places, with one side panel having to be fitted slightly differently to the other. This wasn't due to the quality of the 'kit' itself, but rather the fact that the right hand tube that holds the front/back sticks together was fitted slightly lower than the left hand one from the factory (!).
Other than that, it was fairly straightforward, with all the rivets supplied, in bags, labelled with which panel they were destined for. I chose the natural aluminium finish, but you can have it powder coated for extra cost. However, I'm glad I didn't go for that due to the fact I had to use a hammer to 'encourage' the rear panel to fit so I was happy with it.
The kit comes supplied with the rear door already rivetted into place as a side opener. I wanted the door to open as a tailgate, lifting the tilt cover out of the way at the same time, so I drilled out the rivets, and replaced the hinge across the top. I'm sure you could order it this way to start with, as these are pretty much built to order. For convenience, but also as there was no other way of holding the rear door open once I'd changed the hinge over, I fitted a gas strut to one side. This seems to work great, steadily opening the door up out of the way, as soon as the 2 locks are disengaged.
The only let down (if you can call it that), was the delay in getting it delivered to me. Apart from not letting me know it hadn't been sent out (the second time it was due to arrive), Patriot were pretty good to deal with.
In all, it does appear to be a very secure cage, and I reckon it'll do exactly what it's designed to. The only other mod I'm going to make is to attach another piece of ally across the door's lower edge, so that it closes across the drop down tail gate. This would mean that the locks (also supplied with the kit) would do the job of locking both the upper door & lower tail gates.
I've attached a few pics below (sorry, I forgot to take any during the fitting stage!). If anyone's got any questions, or wants any help/tips with fitting theirs if they buy one, please give me a shout .
Final View when fitted:
Rear door/tailgate open:
Inside Left View:
Inside Right View:
Gas Strut:
Rear Door Closed:
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Mark
2011 110 XS DC
Stornoway Grey
Post #101646 22nd Nov 2011 3:05pm
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
Thumbs Up
Do they have that kit in black ?
It's on my wishlist for Santa ! Whistle Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #101650 22nd Nov 2011 3:26pm
twopoint6khz
United Kingdom 2005 Defender 110 Td5 CSW Java Black
Hammerite make a black version.... Thumbs Up
Post #101652 22nd Nov 2011 3:33pm
MuddyMarky
They powder coat it black. I think he said approx £50 (?) and it takes a few days extra. Best thing is to give them a ring Thumbs Up Mark
2011 110 XS DC
Stornoway Grey
Post #101653 22nd Nov 2011 3:34pm
lrmaniac
thanks! Thumbs Up
btw ... those gas struts is part of the kit or is diy ? and does it have a lock ? Regards
Joao
'08 BMW F800GS
'69 SIIA 109 ZA CKD
Post #101656 22nd Nov 2011 3:36pm
MuddyMarky
DIY.....Range Rover bonnet strut Mark
2011 110 XS DC
Stornoway Grey
Post #101657 22nd Nov 2011 3:37pm
leeds
Hi Joao,
The standard finish of the tilt security cage is natural as shown. Yes I am sure Patriot will get it powdered coated for you. Minimum charge for powder coating is £25 + VAT. Alternatively we have several powder coaters close to us so if you wish your tilt security to be shocking pink I am sure that I can arrange it! Laughing
Current retail price is £674. Not sure what carriage would be to Lisbon however.
HTH
Brendan
Post #101660 22nd Nov 2011 3:40pm
lrmaniac
...pink I'll pass !! Mr. Green
It's a great piece of kit, very usefull .... just haven't convinced myself to put a side 800€ to get one ... Whistle althoguh I want (and could use a lot) one! Regards
Joao
'08 BMW F800GS
'69 SIIA 109 ZA CKD
Post #101663 22nd Nov 2011 3:58pm
leeds
Just trying to be helpful Joao Laughing Whistle
We sometimes can get slightly different/unusual/one off things done for customers.
Brendan
PS I am surprised Barbara daughter has not asked for pink rock and tree sliders YET!
Post #101668 22nd Nov 2011 4:18pm
Mark_110DCPU
United Kingdom 2001 Defender 110 Td5 DCPU Chawton White
Blimey - another one! I thought I had the only one...
I have also modified the door to open upwards, but I thought that having exposed rivet heads rather compromised the security aspect of the cage, so the hinge is installed in the same way as the original side opening one...
Mine is Black, and is far less obvious as a result - I guess I should take some pictures of it...
Mark [:O|===|O:] 2001 110 TD5 Doublecab
Post #101669 22nd Nov 2011 4:19pm
MuddyMarky
I also re-mounted the hinge/rivets in the same way as it was supplied originally. I assume the bottom line is that if someone is willing to drill out the rivets, then it wouldn't really matter what vehicle/arrangement I had.....ie, they'd get in somehow anyway! Mark
2011 110 XS DC
Stornoway Grey
Post #101672 22nd Nov 2011 4:26pm
Please don't take this the wrong way - I'm genuinely intrigued. Given the cost and the faffing about with the door, why not just fit a hard top of some description? Darren
Post #101677 22nd Nov 2011 5:05pm
MuddyMarky
No problem....I had an IW top before this. It wasn't at all water tight. I've managed to get my tilt to be pretty much that now, with a little time and patience. The 'faffing' about with the door took me approx 30 minutes, including the fitting of the gas strut. Also (and probably the biggest thing) I much prefer the look of the canvas tilt on the DC.
It's also able to be locked, and as I said above, I'll be able to also secure the lower tail gate at the same time with a small mod.
The cost was £674 delivered, inc VAT, so I appreciate I could get a thin ally hard top (such as another IW/Gamic, etc), but they would also be much easier to get through than the cage above (they are made of much thinner material).
I know it perhaps isn't to everyone's taste, but a couple of people showed interest the other day, so thought I'd get a thread going Smile Mark
2011 110 XS DC
Stornoway Grey
Post #101681 22nd Nov 2011 5:18pm
Hi Mark,
Nothing to do with taste - your truck, your choice - I just wondered if there was some particular benefit to this set-up over a conventional hard top. Darren
Post #101684 22nd Nov 2011 5:38pm
Buzz
2010 Defender 110 Puma 2.4 DCPU Tonga Green
Hi Mark,
Thanks for posting this as I was interested. Looks great!
Post #101688 22nd Nov 2011 5:53pm
