Home > Tdi > TDI 200 Fuel Injector Pump
Page 3 of 11 <123 4 ... 91011>
cykoh85
Malaysia 1990 Defender 110 200 Tdi SW Santorini Black
Dinnu wrote:
What you show above is the high pressure fuel lines from the injection pump to the injectors.
Do you mean you want to remove the injection pump? Its a bit more involving to remove the injection pump, as you would need to remove the timing belt.
The lift pump is more towards the rear of the engine block, still drivers side, and it only has 2 lines, an In and an Out.
I won't be removing the injection pump, but I plan to change its O-ring during the next service.
Anyway, I'll remove the high-pressure fuel lines too, to replace the oil filter housing gasket.
As long as no fuel comes out when removing the fuel lift pump, it should be an easy job.
Thanks Bro Cool
Post #1015598 19th Nov 2023 6:17am
Dinnu
Note that if you take the high pressure fuel lines out, a small amount of fuel will come out from the injection pump. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1015599 19th Nov 2023 8:07am
cykoh85
Oh I see, so I'll need to bleed the fuel system after that?
thank you Smile
Post #1015635 19th Nov 2023 2:15pm
Dinnu
Usually leaving the high pressure lines loose at the injectors and cranking until fuel leaks there is enough to prime the injection pump. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1015649 19th Nov 2023 4:21pm
cykoh85
Ok, thanks Bro Dinnu Cool
Post #1015700 20th Nov 2023 7:24am
cykoh85
thank you Smile
Hi Bro Dinnu, today, when I change my engine oil and want to open the oil filter housing bolts to change the gasket, my question is: do I only need to remove two bolts, or is there a third bolt as well?
When I removed two bolts, it was quite difficult to take off the oil filter housing. I suspect my mechanic might have used RTV silicone without the gasket the last time.
I'm saying this because for both my fuel lift pump and its mounting, as well as the brake vacuum (which has a triangular shape), they only used RTV silicone without a gasket.
That's why I've noticed minor leaks in those areas. Today, I managed to change the brake vacuum gasket, but I could only replace one gasket as the triangular metal part was difficult to remove.
thank you. Smile
Post #1016519 27th Nov 2023 3:00pm
Dinnu
LRWorkshop is an extremely good source of information to check assembly drawings and part number. Here is link for the 200tdi. https://www.lrworkshop.com/diagrams/land-r...ine/200tdi
For your quesions on how many bolts are used on the oil filter housings, you can see that there are 2 in the following diagram.
https://www.lrworkshop.com/diagrams/land-r...ptor_53148
All the components that you mention are assembled on gaskets at the factory. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1016539 27th Nov 2023 5:47pm
cykoh85
Ok, thank you for your info.
Hard thing is to remove the plate from the block.
Anyway, I'll try again when I change the engine oil next round.
Thanks Smile
Post #1016591 28th Nov 2023 1:42am
cykoh85
Hi Bro Dinnu, I wanted to check with you about the fuel lines; they are only tightened by hand force, right?
I've noticed some minor fuel leaks from number 2 and number 3. Can I use PTFE tape to wrap the threads?
thanks Smile
Post #1017244 3rd Dec 2023 1:47pm
Dinnu
As far as I know, the high pressure pipes are flared, so no use of ptfe tape. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1017257 3rd Dec 2023 3:36pm
cykoh85
alright, thank you Bro!
I will tighten it again.
Post #1017678 7th Dec 2023 1:34am
cykoh85
Hi bro, I wanted to confirm something about the TDI 200 turbocharger. Does it automatically receive oil from the engine oil to provide lubrication?
thank you.
Post #1017697 7th Dec 2023 1:08pm
Dinnu
Yes, there is an oil feed from the side of the engine block, and goes to the top of the turbocharger. Then there is an oil drain below the turbocharger to drain the oil back into the sump. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1017702 7th Dec 2023 1:59pm
cykoh85
Alright, it is saves time as there's no need to change the oil separately, unlike other turbochargers.
thank you Smile
Post #1017706 7th Dec 2023 2:17pm
cykoh85
thank you.
Hey Dinnu, I need some advice. A few days ago, my clutch pedal cannot press to down at all, so I just forced it down, and it lost its elasticity. After some investigation, I discovered a leak at the bottom of the clutch slave pump (please refer to the attached photo).
My question is, is the issue solely related to the clutch slave pump, or could there be other underlying problems? I've already placed an order for a new clutch slave pump, and it's on its way for delivery.
Thank you.
Post #1018345 14th Dec 2023 10:50am
