![]() | Home > Maintenance & Modifications > DIY wheel alignment/tracking |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17853 ![]() ![]() ![]() |
If you do enough mileage the tyre wear will tell you haw good your tracking is.
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6198 ![]() ![]() ![]() |
Yes. I recently changed both front tyres. Outer edges were both worn so I suspect too much toe out.
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3357 ![]() ![]() ![]() |
I've got one of those. Think I try it out as well as string method and see what works best for me.
Cheers for that. |
Good timing this thread, as mine is out all of a sudden. I'll do some research.
![]() I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
Thanks for all the advice. I finally got around to doing the tracking today. Quite a bit of adjustment was needed but it didn't take long. In fact it seemed too easy so I popped the truck into ATS to check my work. They said it was near enough bang on so there was no charge.
Happy days! |
Yes surprisingly easy isn't it?
It was, which honestly shocked me because I'm a crap home mechanic. For many years I believed tracking was a dark art beyond mere mortals and those without expensive laser guages. But no more!
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2347 ![]() ![]() ![]() |
So for my own clarity, the correct specification is 2mm toe in based on a 16" wheel diameter?
Is that 2mm net? ie 1mm in at the front 1mm out at the rear? Or 2mm in at the front, 2mm out at the back > 110 XS Double Cab |
2mm at the front.
edit: my Td5 manual states 0-2mm toe out |
Yes. Everything I find says out as well
![]() https://www.4x4community.co.za/forum/showt...re-problem https://www.defendersource.com/forum/f6/11...66412.html > 110 XS Double Cab |
DefenderCan Member Since: 25 Nov 2023 Location: Canada Posts: 1 ![]() ![]() ![]() |
Handling my alignment in the my drivewa today . Just replaced my rotors, wheel bearing, brake pads as well as replaced calipar pistons on my rears. Hub locknut torqued to 210nm.
Nonetheless the car rolled fine with no pull. My tires are 235/85/16 and were at 35 psi in the front and 36 rear. I now reduced them to 29.4 front and 34 rear. A couple of days ago I was driving and noticed a light pull to the left. Did a string diagnosis on the alignment and noticed all are square except the front right tire which seems to be toe in. I see no bend in the track/tie rod or drag link, steering is centralized provided the m8 bolt alignment. The location I am in has unforgiving roads. Can one tire fall out of alignment? Is it possible for one side of the tie/track rod to skip a thread over hard bumps or my drag link? Would appreciate a seasoned opinion on what the issue could be? Thank you lads |
