Home > Faults & Fixes (L663) > Failed Signature DRL fix
Tim in Scotland
PowerfulUK has launched a fix for the component in the signature DRL that fails
?si=A9ElI1TL3iyHNG9j Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Post #1016192 23rd Nov 2023 7:07pm
lightning
Well, that's fabulous news because these light units are nearly £3,000 each and once out of warranty you are on your own.
Post #1016198 23rd Nov 2023 7:30pm
Moo
Ukraine
Shocked How much!
That’s just bonkers. Once the thieving parts scumbags realise the cost of these things then expect to see a rise in thefts Twisted Evil Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Post #1016214 23rd Nov 2023 10:10pm
J77
Yes, had both replaced under warranty on my Velar as they were cracking, it was a battle. £2.5k + VAT per corner. The rears cracked as well, though there was a technical bulletin for the rears 24MY 90 D250 HSE, Tasman Blue
Post #1016215 23rd Nov 2023 10:48pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
The chip he is talking about has been available for quite some time now, you can get them from China for about £15, as usual it's not something he has discovered, he is just copying what other people do and then will charge a premium for it Rolling Eyes Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #1016220 24th Nov 2023 12:57am
jim4244
England 2013 Defender 90 Puma 2.2 CSW Fuji White
£3000 each!…… Shocked how is that even possible? You could buy a half decent Ford Fiesta run around for that money or even an old style Defender that needed a little bit of work.
Land Rover really have alienated their old school supporters….☹️
Jim
Post #1016224 24th Nov 2023 5:47am
Martin
Site Admin
Classic Defender headlights, £20+VAT each. Progress Wink  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1016226 24th Nov 2023 7:44am
Co1
Rolling with laughter Rolling with laughter
Post #1016236 24th Nov 2023 10:19am
Retroanaconda
The standard base spec lights are much cheaper luckily.
Post #1016280 24th Nov 2023 7:59pm
TexasRover
I am getting old I suppose, but when I shop for a second hand car, I do research on what fancy stuff to avoid because when it breaks it's typically expensive to fix.
So when I am ready to buy my pretender I will be looking for the base spec.
Post #1016281 24th Nov 2023 8:03pm
lightning
There's often ways around replacing these expensive parts, as above. lf it's a common failure there's likely to be an aftermarket alternative or a repair possible, as the vehicle gets older and aftermarket companies start looking at ways to make money from it.
Post #1017586 6th Dec 2023 9:17am
WizzardPrang
That's what I did buying it from new and was pleased, much later, when I discovered how much the fancy ones cost to replace. Thumbs Up Current vehicle: 2020 Defender 110S
Gone: Defender 90 HT 200Tdi, Discovery Sport, Freelander 2
Insta: wizzardprang
Post #1017676 6th Dec 2023 11:08pm
