Home > In Car Electronics (L663) > Rear Windows Activation 110 Hard Top |
craigblues Member Since: 02 Aug 2015 Location: Worcestershire Posts: 11 |
Fair enough. Door Panel / Card easy enough to remove?
Ah that could be an option if you can make the motor live with a battery to test etc. |
15th Nov 2023 11:14am |
mattlidster Member Since: 17 Jan 2017 Location: UK Posts: 17 |
Yes once i got my head around the silver Allen keys were a bit of a red herring! IIRC its 1 screw in handle recess and then the rest is just clipped on. then to remove old harness there is about 12 black screws holding frame work in place. Again I will try and photo them when I get back to storage, the clips hold int harness in place were a bit of a s*d!!
15th Nov 2023 11:19am |
Paladino Member Since: 07 Dec 2022 Location: Serbia Posts: 30 |
Do you maybe have part number for the rear right door harness for MY23? I did the left side but still to do the right one.
If anyone needs help with coding part feel free to send me a pm. |
24th Nov 2023 11:46am |
New wiring loom Drivers side rear door LR171801
New wiring loom Passenger side rear door LR171817 ( I think that's the right way round!) |
24th Nov 2023 5:01pm |
Thanks! Is this for my23? The connector that goes to the locking mechanism has changed from my22 to my23
24th Nov 2023 5:19pm |
Ah sorry mine is a 72 plate so not 100%
24th Nov 2023 5:34pm |
72 should be my23. Thanks! Do you maybe have a photo of the connector so we can check?
24th Nov 2023 5:45pm |
not brilliant as dark out there and not much space!
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge |
24th Nov 2023 8:35pm |
If its the locking mechanism inside the door I have the old loom I took out that will still have that attached and can take pics of that tomorrow for you.
24th Nov 2023 8:36pm |
Yes, it's the locking mechanism connector that has changed. For the left side I had to disassemble the used wiring loom with old the connector, and the original one that I had on the car. I would like to avoid that job on the other side
The original wiring loom had two connectors, one to the door module and one to the locking mechanism. And they managed to make it different it in less than 3 years of production. |
24th Nov 2023 9:32pm |
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge |
25th Nov 2023 5:41pm |
Thanks. There are definitely two different connectors depending on the year. The photos that you attaches work for the my23.
It looks like that the previous years have a different connector: Click image to enlarge I have finished one side and edited the ccf files. The the wiring for the other side will arrive in a week. Click image to enlarge Did anyone manage to activate the rear door lights and ambient lights? I didn't see anything in the ccf-s... |
1st Dec 2023 9:49pm |
Those seats look good are they Range Rover ones? any pics of the floor frame? Or the conversion?
3rd Dec 2023 9:54am |
Yes, the seats are from a first gen L405, cooled and heated, I did the conversion myself. Please send me a DM if you need more info or pics.
For the rear door puddle lights and ambient lights - unfortunately they are powered and controled by the bcm/gwm and not from the door module, so new wires will need to be installed for them to work. I will try and find the pins for the connector on the door (the retrofited door installation already has all the wires) |
5th Dec 2023 9:41am |
