![]() | Home > In Car Electronics > Heated Windscreen Fault |
Evil Elsie Member Since: 25 Feb 2023 Location: Cumbria Posts: 218 ![]() ![]() ![]() |
Hiya,
Is it 'factory fitted' or an aftermarket screen..?? An aftermarket screen should/could have a timer relay between the switch and the power relay i.e. Pushing the switch in the dash starts the 'timer relay' off which energises the 'power relay'. Good luck.. Dave. 2002 Land Rover 110 Td5 Utility 1990 Suzuki GSXR 1100L 1980 Yamaha RD 350LC 1976 Yamaha RD 400C |
Also note it will only work with the engine running, it will not work if you just turn on the ignition.
Scothern96 Member Since: 22 Oct 2023 Location: Derby Posts: 2 ![]() ![]() ![]() |
Hi,
This is a factory fitted screen but is does have a timer. Is there any way to check that this is working correctly? I have tried it with the engine runner and the relay is still not activating. |
Have you traced the earth? Should be a big one from the screen and a smaller one from the relay. Because the light is not coming on I suspect that power is not exciting the relay. Or the relay is faulty. Test whether the switch is getting 12v first then work towards the relay. Multimeter is your friend here. Just be methodical.
