![]() | Home > Puma (Tdci) > Transfer box rear flange on Defender Puma |
Roukmuth Member Since: 25 Sep 2022 Location: Aurillac Posts: 3 ![]() ![]() ![]() |
Hello everyone
![]() I have just removed the transfer box rear flange from my Defender 90 Puma (2013). I have an oil leak from the handbrake drum and I'm going to change the seal. I am surprised because the mudshield is strongly attached to the flange and I cannot separate them (1st photo). Also, the mudshield mounted on the flange is different from the spare one I purchased (FTC4941- 2nd photo). In my case this is not a problem because I can still change the seal. But how can I do if I want to change the circlip or the 4 screws ? ![]() Thank you for your advices ![]() ![]() ![]() Last edited by Roukmuth on 8th Nov 2023 6:14pm. Edited 2 times in total |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 788 ![]() ![]() |
did mine a while ago..I got the oil seal flange and mud shield so the shield is a seprrate item and will press off the flange.. but there is no need if you are replacing the lot....again from memory the only way I could have changed the bolts was by removing the flange and taking the circlip off, ill have to check that next time im under it ,, but think my bolts would be to long to remove by just shifting the circlip |
Thank you Dinnu for your quick reply
![]() I followed your advice I have shifted the circlip in correct position and expand it to allow the bolt to come out. Unfortunatly the bolt is still blocked by the mudshield ![]() ![]() Last edited by Roukmuth on 8th Nov 2023 5:55pm. Edited 1 time in total |
As above. ![]() It is known for oil to seep along the shaft splines and bypassing the seal. Smear a little RTV sealant on the splines before putting the flange back on. It is belts and braces, but it will keep the oil from the inside of your transmission brake. |
thats basically what I was saying...the bolts are to long to remove in situ without removing the flange and obviously the mud shield has to be removed if it comes off on the flange , but that seems odd..my mud shield stayed on the casing when I removed the flange.. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17876 ![]() ![]() ![]() |
The mudshield is a light drive fit on the flange and not difficult to remove using either a puller or by supporting the mudshield and driving the flange out of it. It is highly likely that it won't be reusable afterwards though.
There is a well-known aftermarket manufacturer whose mud shields seem to bear very little resemblance to the originals and when no alternative has been available I have had to machine them in the lathe to allow them to fit. |
That's interesting.. As I said above my mud shield was left on the transfare box when I removed the flange.. I don't know enough about the defender to know that that is not right.. You are saying its designed to be a press fit on the flange and rotate with it..
Am I picking that up correctly🤔 |
Yes, the mud shield is part of the flange assembly.
Thanks |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3588 ![]() ![]() ![]() |
So I might have had either loose fitting holes for the bolts, or a smaller mudshield ![]() 2012 90 CSW, 2.2TDCI, Santorini Black |
Thank you all for your help
