Home > Maintenance & Modifications > Spare Wheel Lock
toby9946
United Kingdom 2015 Defender 90 Puma 2.2 Landmark LE Corris Grey
Spare Wheel Lock
Just in case anyone else is wondering like I was the Sawtooth spare wheel lock on eBay with the "FortXLocks" also fits on the Dual Finish Alloys........
http://www.ebay.co.uk/itm/Sawtooth-Wheel-L...SwgQ9Vu~Iz
 -2015 Defender 90 XS Landmark-
Post #464046 17th Oct 2015 2:20pm
Sadi
Namibia 2016 Defender 110 Puma 2.2 Heritage Edition SW Grasmere Green
Thank you for posting.
There are 2 types - one for Boots/Dual Alloy and one for Sawtooth - one needs to specify when ordering.
Seller was unsure whether it will fit the steel variants.
Will report back once received and fitted.
Post #465222 21st Oct 2015 12:26pm
I doubt that it would fit any of the steel wheels since the hole in the middle of a steel wheel is much bigger.
I don't see why the same locking principle shouldn't be adopted though.
Post #465268 21st Oct 2015 3:03pm
ericvv
That's what I call a tasty discreet update with a purpose. Thumbs Up
Would the entire item, including screws, bolts, and the lock be rustproof? It is very exposed to the elements of course, and you don't want to face the situation where you can't turn the key anymore due to a rusty lock mechanism.
I think the looks are perfect, so when I come home again end this week, I will check if it would be possible to fit on my Aussie Kaymar wheel carrier.
Eric
P.S. There is some conflicting info in the posts. OP says that the version for Sawtooth also fits the Dual Tone wheel.
Then Sadi says that there is one for Boosts/Dual Tone and another one for Sawtooths.
?????? You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #465312 21st Oct 2015 6:26pm
Sadi
Hi Eric,
The seller acknowledged there to be a different sized washer for the 2 mentioned wheels.
My vehicle will have steel rims - but I received a complete Boost wheel as a gift from a friend.
I will thus replace the steelie spare (store it in a cool dry place) and hide the difference beneath a Defender specific cover.
Post #465336 21st Oct 2015 8:00pm
Sammyboy
United Kingdom 2012 Defender 110 Puma 2.2 USW Sumatra Black
Are these still available anywhere? The original seller does not appear to be contactable anymore. I would want one to fit a Dual Alloy wheel on my Puma 110 USW. Alternatively are there any other similar products on the market?? Bow down Discovery 4 HSE
Defender 2.2 110 USW XS
Ford Kuga AWD
Discovery 3
Range Rover P38
Discovery - 300 TDI
Discovery - 200TDI
Post #712842 17th Jun 2018 6:28pm
Sulisuli
Unable to get these anymore but Brendan a forum sponsor does a great lock for the spare wheel. Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #712853 17th Jun 2018 6:58pm
mk1collector
As above, 4x4overlander Thumbs Up Ray
My build thread
Post #712856 17th Jun 2018 7:00pm
Sammyboy
Sent a message to maker/seller of these on Ebay. Got a response today: "due to illness he has stopped making them for a while but intends starting again when feeling better" so if interested keep watching Ebay. Discovery 4 HSE
Ford Kuga AWD
Discovery 3
Range Rover P38
Discovery - 300 TDI
Discovery - 200TDI
Post #713070 18th Jun 2018 8:17pm
foggydave
United Kingdom 2014 Defender 110 Puma 2.2 USW Bonatti Grey
I had to renew a locking nut on one of my wheels and was surprised as to how few combinations of lock nuts there are. The actual letter is stamped on the nut so all the scrotes have to do is have a selection and nick my spare.
SO
Here is a spare wheel lock I just made using an SAS caravan corner steady lock, an M36 steel washer and some screwed rod. The yellow one is a prototype which shows up clearly and the black one with yellow ring is the finished article. Pretty much as the one on the first post.
SAS lock £21 M36 washer 50p screwed rod nuts and washers approx £2.5 Welding one rod. total materials inc paint and lacquer £26.
Post #713427 20th Jun 2018 12:19pm
BobT
United Kingdom 2015 Defender 110 Puma 2.2 USW Santorini Black
Re: Spare Wheel Lock
I have one of those too, looks good and not only secures the spare but shows you take security seriously so might put someone off having a go at your Defender other than nicking the spare.
Post #765204 24th Mar 2019 7:25pm
markb110
Hi
To answer an earlier question this kit can be modified to work with a steel wheel.
Instead of mounting the main part to the outside of the wheel carrier, I cut a hole and fitted from the inside, spaced out to suit the wheel thickness.
I then cut a disk (as best I could) from a sheet of alloy with neoprene stuck to the back to prevent scratching and allows a little give when installing the padlock.
I hope that this helps someone.
Mark
Post #765387 25th Mar 2019 9:57pm
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Looks good Mark. What are the shiny dots around the edge of the wheel rim?
Post #765442 26th Mar 2019 12:20pm
markb110
Hi Kmac
The silver dots around the wheel are unpainted rivets, not sure if they are practical or just decorative.
Post #765561 26th Mar 2019 10:12pm
Andy T
United Kingdom 2011 Defender 110 Puma 2.4 SW Fuji White
Non-sawtooth spare wheel lock
In case anyone's interested, I'm going to list one of these for sale... 2011 2.4 White 110 CSW LHD
1998 300TDi Wolf TUM
2015 2.2 Corris Grey 90
2009 2.4 Alaska White 110 Commercial - gone
2006 TD5 Barolo Black 90 - gone
1995 TD5 Green 90 - gone
1984 2.25 Marine Blue 88
Post #1014258 7th Nov 2023 6:50pm
