Home > Td5 > TD5 Idler pulley bearings - Replacement
geobloke
So, I have fallen foul of fitting a replacement pulley to Miffy without checking whether the bearing inside the pulley had any grease. Nope, pretty much dry as a bone in there. So I have greased it, but it will need replacing at the next service.
The pulleys in question are:
ERR6658 - Idler pulley all engines.
ERR6493 - Idler pulley non-AC
I suspect they are the same bearing inside, but does anyone else know for certain?
Any bearing part numbers for SKF or Timken or alike?
A quick search provided these measurements for ERR6493
OD: 47mm
W: 14mm
From this website https://www.bearingoptions.co.uk/replaceme...ey-bearing
Post #1014233 7th Nov 2023 4:24pm
geobloke
Ok, confirmation through a deep dive into the search panel gives me this thread
https://www.defender2.net/forum/post941642.html
So both pulleys use the same bearing. That is one question answered. Thumbs Up
and the bearings both had 6303 LHA embossed on them, which is the same bearing, according to a Russian site as SKF 6303.2RSR.C3.
So, looks like I am heading in the right direction.
Post #1014246 7th Nov 2023 6:03pm
geobloke
A bit of extra learning this evening. To tell you the truth I have never paid attention to what the numbers on bearings actually mean.
So the 6303 2RSR C3 code means:
The '6' = Deep groove ball bearing (single row) - Suitable for light axial loads as well as radial loads.
'303' = Bore diameter I believe
'2RS' = Bearing with rubber seal on both sides. RS provides a better seal but more rolling friction than 2Z (Bearing with metal seal on both sides)
'2' = TBC
C3 = Internal clearance code.
Fascinating really, well it is to me anyway.
Post #1014259 7th Nov 2023 6:52pm
barbel jim
I did mine not that long ago, and genuine land rover were on back order Big Cry
Post #1014261 7th Nov 2023 6:56pm
geobloke
And probably will be for quite some time I would expect.
Apparently the above bearing code is the OE bearing used on some Mercedes Benz's.
OE 990 990 74 00 — MERCEDES-BENZ
OE A 990 990 74 00 — MERCEDES-BENZ
OE N 000625 436303 — MERCEDES-BENZ
Post #1014263 7th Nov 2023 7:02pm
Screbble
'2' = TBC
Thanks for sharing - sadly I too find that interesting!
Whilst on the subject of idler pulleys - I’ve had a couple of non LR pulleys that have been awful quality so I’d tend to opt for LR.
Post #1014265 7th Nov 2023 7:07pm
geobloke
I believe this is where my issue stems from. Poor quality bearings that may or may not have been greased. The pulleys seem fine and I hate to throw away perfectly serviceable items, hence replacing the faulty bearings.
Goodness, prices go up and quality goes down... Big Cry
Post #1014268 7th Nov 2023 7:21pm
geobloke
Bearings ordered Thumbs Up £11 all in for a pair of Timken bearings. Cannot complain at that price.
Buying the full pulleys would cost £55.05 before P&P for Britpart items and a whooping £159.61 for LR items Rolling Eyes
Just need a little vice and drift action and job done.
Post #1014270 7th Nov 2023 7:33pm
Screbble
Ah Timken - Carlsberg Thumbs Up
Post #1014335 8th Nov 2023 8:51am
rustandoil
This is good stuff, well done for searching out the bearing numbers Thumbs Up
Post #1014342 8th Nov 2023 10:09am
geobloke
No problem. I will see how feasible the bearing swap actually is when they arrive Thumbs Up
Post #1014348 8th Nov 2023 10:34am
rustandoil
It would be great if you could report back here with your results Thumbs Up
Post #1014366 8th Nov 2023 12:58pm
geobloke
Of course. Goes without saying Thumbs Up
Post #1014369 8th Nov 2023 1:07pm
I did a similar exercise not too long ago on my 2.4 Puma and replaced nearly all of the supposedly non-replaceable bearings. It was relatively quick, relatively cheap, and hugely satisfying!
Post #1014427 8th Nov 2023 7:26pm
geobloke
It is all about the satisfaction Thumbs Up
Post #1014428 8th Nov 2023 7:28pm
