Home > Maintenance & Modifications > Track rod /ball joint
tolley
United Kingdom 2006 Defender 90 Td5 CSW Oslo Blue
Anyone tell me which is the right ball joint, for the passenger side ball joint from the steering arm .
Is it RTC5869
Post #1014069 6th Nov 2023 11:57am
Dinnu
As far as I recall, the swan neck has a left hand thread, so you should be getting a RH thread, hence your part number seems to be correct (also when you buy a kit with 3 ball joints, you get 2x RH).
Of course this is as long as you still have the Defender drop arm.
Edit: I refer to the drag link rather than the track rod. For the track rod, there is always the possibility that someone had inverted the ends. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1014073 6th Nov 2023 12:08pm
geobloke
Everything you need to know can be found here
https://www.lrworkshop.com/diagrams/land-r...mper_53717
RTC5869 is item 3.
Post #1014090 6th Nov 2023 12:58pm
tolley
Many thanks looks like number 3 is the right one .
Post #1014114 6th Nov 2023 5:27pm
