Home > Maintenance & Modifications > cross member bolts easy to swap?
Page 3 of 3 <123
nitram17
if your using stainless bolts i would not use copper paste as that will be copper,ss,and ali in contact with each other! use ceremac ,duralac or some other non metallic anti seize paste,,in truth you are just trying to dispel and keep water out of the contacts as its moisture that drives the the problem,duralac does have a tendency to go hard though thats why i prefer the ceremac paste,
Post #1013877 4th Nov 2023 12:03pm
peanutbob
All fitted and much smarter! I had some Lithium grease in the garage…so I used that for the threads. I hope that will be ok!
Post #1013889 4th Nov 2023 1:30pm
The other thing worth including are some nylon washers to separate the bolt heads/regular washers from the bodywork:
More details here: https://www.defender2.net/forum/post829011.html#829011 Darren
Post #1013896 4th Nov 2023 2:14pm
Screbble
Yes I agree on the nylon washers 👍
Post #1013923 4th Nov 2023 6:09pm
Page 3 of 3 <123
