![]() | Home > General & Technical (L663) > Where to put my gas cap when refueling |
| Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1448
I place mine in the semi circular cut out which I think is what you are alluding to, I know I have to slide the tether around sometimes to get it to fit correctly. Cheers Ian
-------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
| J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3493
As above 24MY 90 D250 HSE, Tasman Blue
| pjeski Member Since: 25 Jul 2023 Location: Michigan Posts: 115
Excellent. Got it now. I was trying the wrong part of the cap, then I tried the tether itself (as another car of mine does). Thanks.
| Moo Member Since: 01 Oct 2021 Location: UK Posts: 1472
I put mine in the towing eye.
Your tether is probably stretchier than mine.
| Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2762
Mine just hangs on the tether, is that not what it’s for?
| chpsk8 Member Since: 26 Sep 2023 Location: Midwest Posts: 49
So does the cap sit in that indent, or does the tether? I can never get any part of the cap to sit in the indent, it always falls off and bangs into the car. I’m sure I’m just doing it wrong.
| David007 Member Since: 26 Oct 2022 Location: Angus Posts: 112
This is mine and the cap sits in the indent. Hopefully you can see from the pictures how it should sit.
| LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1281
I just let it dangle, never bothered me....
Yep, that's how mine fits -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
| Down & Dirty Member Since: 15 Sep 2023 Location: Somewhere outback Posts: 93
^^^as above sits on flap
Ok, that’s what I keep trying. My tether has so much spring in it, it just pulls the thing off!
Maybe I’ll take a heat gun to the tether and see if I can get some of the spring out of it. Thanks for the clarification! |
| Defendit.. Member Since: 09 Aug 2020 Location: 's-Hertogenbosch Posts: 457
Design flaw nr... ?? No Mud flaps for my 90.!
----------------------------------------- P300S MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
| Nuclear Nick Member Since: 21 Aug 2021 Location: Southwest Posts: 310
I keep trying to sit the cap in that groove but as soon as I shove the petrol nozzle in the filler neck it knocks the cap off its perch!
