![]() | Home > Puma (Tdci) > Retrieve object from cylinder!!! |
SilverPuma Member Since: 27 Oct 2023 Location: Devon Posts: 51 ![]() ![]() ![]() |
The blank is in the pit of the dished piston so should be able to turn the crank without it fouling the head / valves.
Wondering if it’s possible to “drop” a valve so there’s enough clearance to get it out. I know that usually exhaust valves have greater lift otherwise although smaller? |
Not sure if anyone has a TDCI camshaft around but the excess lobe size should give the valve lift ?
Also thought about using an overhead valve spring compressor which would lower the valve further to give me some more room? |
Update
Rocker carrier removed and injector seats all cleaned, inlet manifold removed and overhead spring compressor then used to drop inlet valve onto piston at TDC. Lowered piston by hand turning crank (easy as no compression with injectors) and lowered valve gave me access into cylinder with a Sealey 4mm head magnetic flexible tool. Two minutes later the world looked a better place ![]() Item removed thankfully saving lots of ££££££! |
Colin Member Since: 29 Dec 2009 Location: UK Posts: 12 ![]() ![]() ![]() |
Hi SilverPuma or anyone else with overhead valve spring compressor recommendation,
I have just done the same thing as you and dropped a injector hole seal thinging into the No1. cylinder ![]() Cheers, Colin |
That’s it exactly.
Takes a lot of patience then with the magnet tool, otherwise use compressed air through the injector hole to blow it around and out? That was going to be my plan B! Good luck 🤞 2010 2.4 TDCI Puma Defender 90 |
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 983 ![]() ![]() ![]() |
Result! 👍
Jim |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5986 ![]() ![]() |
Just be careful that the compressed air is not too quick or too powerful, otherwise it may drive the piston down, then dropping your now released valve. That would be a step backward ![]() |
![]() Cheers |
mwestcrew Member Since: 09 Dec 2019 Location: South Warwickshire Posts: 288 ![]() ![]() ![]() |
Were the blanking plugs out of one of the commonly available kits?
Strikes me if there are two people on here that have the same problem that maybe they aren’t fit for purpose. I’ve got a kit and have used it a couple of times, and I understand why the aren’t just simply bigger as you need to clean the injector seat. Maybe you could magnetise the plugs so they wouldn’t want to leave the hole and drop in……….maybe that would make them hard to remove though. 2011 130 Utility Body 2005 110 Van |
I must admit it was a cheap eBay kit. In a way that helped as the blanks were steel and magnetic as opposed to ally. The blanking plug flange could have been bigger to prevent this I’d say. It’s easy to push the blank through the hole accidentally when cleaning the injector gallery using tools etc…… 2010 2.4 TDCI Puma Defender 90
If the piston was at TDC would that hold it it place and prevent it falling in? Or is the insert not long enough for that?
Inserts aren’t that long and pistons are dished 2010 2.4 TDCI Puma Defender 90
Hi,
So first of all SUCCESS ![]() 1. Remove the spring from the inlet valve toward the front of the engine. The engine leans back, so the metal thing is more likely to move to the back of the engine. 2.Lower piston on the problem cylinder and use your magnetic probe through the injector port to locate and grab the lost metal bit. I did this a few times, pulling the magnetic probe up out of the port so I could hear the metal bit drop. This meant I knew I could reliably grab the metal bit. 3. Grab the metal bit through the injector port again, but don't fully remove the magnetic tool from the port. The idea is the metal bit will be at the top of the cylinder. 4. Move the piston back up close to the top then lower the valve you have remove the spring from. 5. Remove the magnetic probe and and try and drop the metal bit to the back of the piston. 6. Stages 3. to 5. should mean the metal bit is not under the valve you are working with. 7. Insert magnetic probe through the inlet port and move the piston up further until the valve is nearly gripping the probe. Hopefully, the top of the cylinder can now be reached by the probe. 8. Wriggle the probe around a bit. 8. Lower the piston and valve again to create some room to remove the probe and hopefully the metal bit. 9. Pull out the probe and either swear and try again (no metal bit) or swear and dance around (metal bit retrieved). The picture below is the shape of the magnetic probe after successful retrieval. ![]() Click image to enlarge Good luck to anyone trying this and thanks to SilverPuma for the suggestions. Cheers, Colin |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3676 ![]() ![]() ![]() |
![]() I hope everyone is well and your land rovers make you happy |
