Home > Puma (Tdci) > Heated Rear Window Switch
Pacha
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
Quick Q guys (not had chance to head out with my multimeter yet).
Should the switch for the rear window heater illuminate when it's switched on? Rgds.
Chris
Post #1012975 28th Oct 2023 2:24pm
Oddly, no. The indicator for the HRW is in the instrument cluster rather than on the switch, completely unlike that for the front screen. Darren
Post #1012980 28th Oct 2023 2:43pm
Pacha
Thanks Darren! Rgds.
Chris
Post #1012981 28th Oct 2023 2:45pm
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
On a Puma? The switch does have an LED though. - I just realised I've never ever turned it on in the eight years of our ownership Smile
Post #1012987 28th Oct 2023 3:23pm
andy63
I've got a 2.2l 2014 truck.. The front screen has to have the engine running to stay on.. With an illuminated led in the switch..
The rear will come on with the ignition on and has an indicator light in the switch and the dash has a symbol that lights.. ๐Ÿ‘
Post #1012989 28th Oct 2023 3:40pm
Ha, funny the things that you miss. I've never noticed the LED on the HRW switch before. I shall have to go and take a look now Laughing Darren
Post #1012994 28th Oct 2023 4:29pm
Confirmed Laughing
 Darren
Post #1013024 28th Oct 2023 9:06pm
Martin
Site Admin
Yes it does have an LED, and itโ€™s switched on using the supply to the switch rather than feedback from the screen circuit (unlike the front screen).  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1013047 29th Oct 2023 8:55am
Pacha
Thanks everybody - something is amiss methinks.
New rear screen but no demist. No LED on switch but that looks like it's not part of the issue?
Need to go over things with a multimeter. Rgds.
Chris
Post #1013125 29th Oct 2023 7:24pm
Does the indicator on the dash com eon when the switch is pressed?
Post #1013126 29th Oct 2023 7:30pm
Martin
Site Admin
Fuse 15 covers the switch input side, but also other stuff including instrument cluster, headlamp relay, electric window/seats aux relay (if fitted). So you'd have other things also not operational - are all these OK?
The integral LED and the cluster warning light are both on the switch output which turns on the relay (not the HRW relay out to the window).
Yes I think this is your problem. The switch isn't sending an output to turn on the relay.
You might have a failed switch, or failed wire from the header where the ignition feed splits to supply all everything above.
Popping the switch out and probing the connector with a meter will tell you if the supply in is OK (ignition on).
Bridging the white/green to the white/black should give a click from the HRW relay and so turn on the screen.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1013154 30th Oct 2023 12:21am
Pacha
Ok, just checked (pouring down here!) and there is no dash indicator when the switch is pushed in.
Will run a multimeter over it when the rain abates. Rgds.
Chris
Post #1013335 31st Oct 2023 12:50pm
Martin
Site Admin
Annoyingly, because it's a blue plug switch it can't easily (without modifying the plug or switch) be swapped with another non-identical switch.
Even then it would be the aircon or heated seat switch which not all Pumas are fitted with of course.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1013337 31st Oct 2023 12:57pm
It's very easy to remove the registration lug from a LR switch though.
Post #1013355 31st Oct 2023 2:54pm
Martin
Site Admin
For the key relating to the slot in the dash it goes in, yes. Not so easy for the plug.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1013356 31st Oct 2023 2:57pm
