![]() | Home > Puma (Tdci) > Terminal Lights |
Morea Member Since: 20 Jan 2011 Location: Asturies Posts: 201 ![]() |
Hello. I need help. Where can I find this Light Terminal? Thank you
Defender Puma 2007. http://www.clublandrovertt.org/index.php?a...ype=avatar |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2533 ![]() ![]() |
Did you mean to attach a picture ? What light are you referring to ?
He won't let me attach photographs. But I've already found it this YPC10549 http://www.clublandrovertt.org/index.php?a...ype=avatar
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6725 ![]() ![]() ![]() |
YPC10549 is just the connector housing, not the terminals inside.
If you need terminals I can supply them. ![]() ![]() |
Thanck Martin. I just need that. http://www.clublandrovertt.org/index.php?a...ype=avatar
That's YPC10468 (different to YPC10549)
How many pins on the one you need, and does it have male or female terminals?
Upsss. Where do I get the YPC10549? http://www.clublandrovertt.org/index.php?a...ype=avatar
male and female. The external part has been broken and is not watertight http://www.clublandrovertt.org/index.php?a...ype=avatar
If 14 ways,
female YPC10549 male YPC10469 Available from any LR parts supplier including a LR dealer (they are genuine LR part numbers). ![]() ![]() |
