Home > Technical > Headlights not working |
How odd. Check connections behind the headlight. Check voltage when dipped beam is on, is it the bulb/lamp or the wiring? It shouldn't be both the dipped beam fuses, but check them too.
I suspect it is an earthing problem though, so go around and check all the vehicle earths are in good order. |
19th Oct 2023 3:14pm |
Inguz Member Since: 06 Sep 2020 Location: In the wild Posts: 100 |
Have you tried changing the bulbs? I had a similar issue recently and it turns out that both bulbs need to be working or none will work. Mind you the bulbs looked fine, but I just chanced putting in two new ones, and viola
24th Oct 2023 12:25pm |
When you say 'replaced the stalk', do you mean indicator one? If so, take a look at the 'switch' stalk, which can also fail. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
24th Oct 2023 12:44pm |
It must be catching... https://www.defender2.net/forum/topic53859-765.html
24th Oct 2023 3:58pm |
DICKO1995 Member Since: 02 Feb 2024 Location: High Peak Posts: 10 |
Hi,
First post on here. Go easy. I’m having a nightmare with fitting Wipac led headlights, should be plug and play but not that simple (for me anyway) So my problem is that I have power to the headlights but only seem to have a low beam. With one push forward on the stalk the low beam comes on, when pressing the stalk forward again nothing changes, as if the main driving beam is not working. The full beam/flash is working and so are the DRL’s which are wired to the led sidelights. I’ll attach a photo of the Wipac fitting instructions. The main beam does work when the brown wire (main beam) and the green wire (dipped) are touching each other with the earth plugged into the connector. So i know that the main beam does actually work but once the wires are put into the connector and connected to the car I only have a small beam of light for both clicks of the stalk. Any help on this would be great. Could be me being stupid Laughing Cheers Click image to enlarge Click image to enlarge Click image to enlarge |
2nd Feb 2024 11:13am |
