![]() | Home > Wheels & Tyres (L663) > BFG Ko2 All Terrain Tyre Pressure 275/55/20 |
Mikemillar89 Member Since: 30 May 2013 Location: Cheshire Posts: 19 ![]() |
Hi do you get any rubbing with this tire size?
Thanks Mike |
Hillbilly Member Since: 13 Dec 2020 Location: Sheffield Posts: 4 ![]() ![]() |
No, not that I’ve noticed. They are fitted to standard style 5095 wheels. Ride is a little firm and slightly noisy, but we are used to them now. Certainly not as noisy as some people report.
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2774 ![]() ![]() |
Does your car not have the TMPS? You can switch between heavy and light load on the driver's instrument panel and it also shows you the recommended pressures.
Tyre choice / size won't meaningfully impact the pressures you need Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
