![]() | Home > Puma (Tdci) > Water ingress coming from heat panel passenger side |
AndreB Member Since: 23 Jan 2021 Location: Brielle Posts: 11 ![]() ![]() ![]() |
Hi,
I have a dripping vent panel at the passenger side (bottom) , it's only happening when it has rained. I have a snow shield at the air inlet so that should not be the problem. Any other ideas where water can ingress into the heating system? It is purely rain water ( I don't have airco) Had: Defender 90 TD5 2001 - 225.000 km Defender 110 TD5 - 2000 - 120.000 Have: Defender 90 Puma 2.4 2010 - 211.000 km Instagram: https://www.instagram.com/landrover_diary/ |
Hi, thanks for the input. I have a snow cover installed for the heater inlet to avoid water and dirt getting in
![]() Defender 90 TD5 2001 - 225.000 km Defender 110 TD5 - 2000 - 120.000 Have: Defender 90 Puma 2.4 2010 - 211.000 km Instagram: https://www.instagram.com/landrover_diary/ |
Jerry Member Since: 13 Nov 2015 Location: Cardiff Posts: 210 ![]() ![]() |
this may help
https://www.defender2.net/forum/topic47380-15.html |
ibsley Member Since: 01 Aug 2023 Location: Nimes Posts: 23 ![]() ![]() ![]() |
Can you share a picture?
