![]() | Home > Puma (Tdci) > Puma Suspension |
MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2681 ![]() ![]() ![]() |
Rears made the biggest difference on my 110, doing the fronts had less impact/benefit but mine was quite new at the time
I put Koni Heavy Track on mine, it seemed a good upgrade - thread here https://www.defender2.net/forum/topic16066.html Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2503 ![]() ![]() ![]() |
Did the mechanic remove the front ones to "test" them? Puma 110" SW ............................................................. Earth first. Other planets later |
lakes Member Since: 08 Jan 2023 Location: Lake District Posts: 22 ![]() ![]() ![]() |
No - I think him saying they were fine meant they weren’t bust open like the rear
Depending on the usage or miles sometimes it is necessary to remove a shock absorber to test them. If it does not leak does not mean it is good. Sometimes they loose their gas charge and internals wear. Puma 110" SW
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17990 ![]() ![]() ![]() |
FWIW my 2007 270k mile Defender is still on the original front dampers.but not rears.
Chicken Drumstick Member Since: 17 Aug 2020 Location: Near MK Posts: 921 ![]() ![]() |
What I find amazing here is. How can any sensible owner not know they have shocks hanging off!!!! Do such owners have their eyes closed shut whenever they walk near to their own vehicle???? Quite worrying that such owners and vehicles are allowed on the roads really.
I’m not a mechanic, hence why I asked advice on a forum - and it’s in the garage every 6 months for inspection/service.
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1673 ![]() ![]() |
i would swap them as long as you dont use britpart oes itll be good for 10+yrs again
If the front are fine, then changing them will make little difference. Do you know many history on the vehicle or how many miles it has done? Is it modded for off roading? Shocks are pretty cheap in terms of car maintenance and you can fit them yourself if you want. So it might not be a bad thing to do. But it depends on what you plan to use the vehicle for on what would be a good replacement. For a budget shock, I quite like the Britpart Cellular Dynamic range. You can get them in stock length or +2". If changing the fronts you'll need some new turret rings are a must. Any brand HD glav ones should be fine. I'd also look at new turrets too. The Gwyn Lewis standard height ones are a good price and an open design. So makes fitting (or removing in the future) easy and they won't trap mud and dirt like the standard design. |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6713 ![]() ![]() ![]() |
Not an acceptable response to anyone on this forum. Do not speak to others like this again. ![]() ![]() |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2682 ![]() ![]() ![]() |
I would replace the fronts as well, but that's me: I like to know that components that work in unison are all of the same age/wear & tear. --
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 886 ![]() ![]() ![]() |
I would get the fronts renewed.... Fresh dampers front and rear can't be a bad thing....
If you're happy with standard spec' that will save you a few quid 👍🏻 |
Matt_H Member Since: 19 Sep 2018 Location: Cornwall Posts: 45 ![]() ![]() ![]() |
The thing is dampers are so cheap that its worth treating them as a service Item IMO (not every year). The rubber bushes all wear with use too, so for the sake of £40 a side every few years, you might as well replace them and have a better drive. Its funny the number of people who swear their dampers are absolutely fine, but then comment on the improvement having fitted new ones !
