Home > Puma (Tdci) > Aftermarket Headlights
Naycrx
Good Evening,
This evening i noticed one of our aftermarket headlights stopped working? Main lights work. But DRL Halo running light isn't, and the same Halo indicator isn't working.
I have had it all to bits , but it's a sealed unit ... is there a possibility that the bulb it the Halo has gone ?
Cheers[/i]
Post #1011581 17th Oct 2023 6:35pm
geobloke
Hello
Just checking that there was a good connection to the indicator and side lights where the power and signal to the DRL/Indicator comes from?!
The way you tap into those wires can make the difference between a good connection and an intermittent one.
Post #1011583 17th Oct 2023 6:40pm
Naycrx
From what I can see there is a red wire from the headlight that controls the DRL and a green wire for the Halo indicator. The normal indicator is working OK?
Os ot worth buying a new set ?
Post #1011588 17th Oct 2023 7:04pm
geobloke
Ok. So the Indicator and DRL work on 12v so run a test wire to the wires in turn and see whether the headlight unit does what it is supposed to.
If that does not work then it looks like those features have died. Is it worth getting a new set? Depends whether you can live with just the main and high beam features and the usual defender indicators.
If you cannot then yes buy a new set. My personal preference is for Trucklites or JW Speaker LED headlights because they work and keep on working.
Post #1011591 17th Oct 2023 7:15pm
Naycrx
OK Thank-you so much for replying, I may sound daft here but where would I run a 12 v test from? Might be best to het an auto electrician ronhave a quick look.
Post #1011597 17th Oct 2023 7:51pm
geobloke
If you are a novice then yes get an auto electrician out to have a look. There is no point (unless you are a keen bean that is) stressing yourself out and risking a short circuit or worse. As they say safety first.
Post #1011601 17th Oct 2023 8:05pm
I think it's actually illegal to have halo indicators as well as the original front indicators. Section 7 Part 11 of the Road Vehicles Lighting Regulations (1989):
"Requirements relating to optional direction indicators
1. No vehicle shall be fitted with a total of more than one front indicator nor more than two rear indicators, on each side
Perhaps your headlamp is trying to save you!
Post #1011618 17th Oct 2023 10:57pm
geobloke
Great catch Blackwolf Thumbs Up I confess I ddi not know this rule. Everyday is a school day as they say.
Post #1011647 18th Oct 2023 9:30am
Naycrx
Thanks all again for the Help... after previous reply I think I'll disconnect the DRL/indicator from the other side now then..... A Temporary fix... but suppose make them legal.
Post #1011648 18th Oct 2023 9:35am
